Thanks for all of your suggestions, most of which I didnt understand. Haha.
This was such a one time, down and dirty thing, all I did was route the track which I was recording on (through a mic set up in front of my monitors) to something other than Main Out 1-2. This got rid of the feedback problem.
As I said, down and dirty. Maybe I'll try Blackhole if it ever comes up again. The name is familiar, I think I may have had that once upon a time.
Gavin
Record computer audio
Re: Record computer audio
Mac mini M1, 14.7, 16gigs RAM, 828 mk3 Hybrid, DP 11.31, Various VIs
Check out System Audio Recorder from the App Store for $7.99.
Works great right out of the box. No Soundflower or ACE needed.
Dislikes:
Only records as M4A (not really a problem, but Wave or MP3 would be nice)
Record volume is a bit low and there doesn't seem to be a way to adjust it
Dislikes:
One might be able to adjust recording level in Setting/Sound/Input. Not spending the $8 to find out, however.Rick Cornish wrote: ↑Mon Mar 03, 2025 6:51 pm Check out System Audio Recorder from the App Store for $7.99.
Dislikes:
The free version of Wondershare does the same but records video—double-click to open in QuickTime to export the m4a.
Unless there's something I am missing, DP can import and convert m4a but cannot record it. One can output DP and Zoom directly to the Wondershare's Speaker Audio Recorder without using an interface or making an Aggregate Device as one needs if bringing Core Audio to the mix. Can System Audio Recorder do the same? The setup would be the same in DP as I showed for the Wondershare at the beginning of my video.
