Stem mixes from Multiple Interfaces
ejv
Post by ejv »
I am trying to send stems to a Dangerous Music 2Bus+ summing mixer using an aggregate Interface setup. I am using a Universal Audio Apollo x8p and a MOTU 828x with the x8p as the main and the 828x as the secondary. I also have drift correction checked on the 828x. No problem sending stems from the 828x but cannot figure out how to send stems from the x8p or if it's even possible. I do see a main monitor mix on the Apollo console going to the 2Bus+ on Inputs 9/10 but that's it. What am I missing here? I have a MacBook Pro using DP11. Thanks, Ed
Re: Stem mixes from Multiple Interfaces
ejv wrote: Sat Mar 01, 2025 12:19 pm I am trying to send stems to a Dangerous Music 2Bus+ summing mixer using an aggregate Interface setup. I am using a Universal Audio Apollo x8p and a MOTU 828x with the x8p as the main and the 828x as the secondary. I also have drift correction checked on the 828x. No problem sending stems from the 828x but cannot figure out how to send stems from the x8p or if it's even possible. I do see a main monitor mix on the Apollo console going to the 2Bus+ on Inputs 9/10 but that's it. What am I missing here? I have a MacBook Pro using DP11. Thanks, Ed
It’s all in the setup of your Aggregate Device. A screen shot should help.
ejv
Post by ejv »
are you asking for a screenshot?
