https://www.pspaudioware.com/products/psp-wobblerNew:
- new presets: Adam Piskorz, Enrico De Paoli, Steve Levine
Fixed:
- vst 2.4 mono/stereo detection
- corbo-billy
PSP Wobbler update v. 1.0.1.
PSP Wobbler Version 1.0.1.
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
Sonnox Plugins Updated
A whole bunch of Sonnox plugins have been updated including Drum Gate, Inflator, Limiter, Reverb, Claro, Voca, VoxDoubler, and more.
Go over to sonnox.com to download the new installers.
- corbo-billy
Repeater update v1.2.5
D16 Group with Repeater new version_
https://d16.pl/repeater
Fixed • Crackles in Dry signal under specific audio interface
buffer settings
• AUVal crash
APU Software Updates
APU Loudness Series updated to 3.4.2
https://apu.software/download/
Release Notes
Version 3.4.2
Multiple file batch exporting (optimizer)
Fix peaks getting through limiter (optimizer)
Click to reset peak meter
Audio Hijack updated from 4.4.6 to 4.4.7
Updated in Audio Hijack 4.4.7:
The “Reveal in Finder” option has been restored to the “Actions” menu in the “Recordings” tab of session windows. This corrects a regression introduced in 4.4.6.
Audio Hijack’s “About” box has been updated with a new design.
- corbo-billy
ODDITY v1.1.2. Update
GForce Software and a Oddity new version _
https://www.gforcesoftware.com/account/oddity3/Bug fixes
CC maps not saving.
MIDI channel setting from standalone affects plugin versions
Mac installer requires rosetta.
MS VS Redistributable added to Win installer
PC AAX not loading default patch on launch.
Re: ODDITY v1.1.2. Update
Thanks for posting this. I noticed I missed the 1.1 update back in October, too. I need to check GForce's site more often. I don't recall getting an email notice about this update.corbo-billy wrote: ↑Tue Feb 18, 2025 10:08 am GForce Software and a Oddity new version _
CC maps not saving.
UPDATE: I stand corrected! I did get an email about it today! Hmmmm...
Softube Updates
Softube Updates
Looks like a whole bunch of their plugins are all updated from v. 2.5.97 to 2.6.1. Run Softube Central to update.
- corbo-billy
Massive X update
Native Instruments update Massive X to version 1.4.6.
_ Fixed memory leak when closing UI in Komplete Kontrol .
Voxengo Elephant updated to 5.6
https://www.voxengo.com/product/elephant/
* Voxengo Elephant 5.6
This update includes the following changes:
* The "out/in" label on the output level meter can now be clicked to trim the output gain, useful when the plugin is used for mixing, to match the output loudness to the original loudness. Can be also used instead of the "EVAL" switch.
To download this update, or change the notification settings, please visit the Voxengo web page at https://www.voxengo.com/cp/updates/
XLN Addictive Drums 2 updated to 2.6
Vienna Synchron Player updated from v. 1.3.1865 to 1.3.2062
v1.3.2062, February 18th, 2025
Added
• Support for alternative tuning systems via MIDI Tuning standard (MTS), MTS-ESP master plug-in, VST/VST3 detune, Scala and keyboard mapping files and manual adjustments
• Flow Support for Synchron Smart Orchestra 2.0 IMPORTANT: Older player versions DO NOT SUPPORT presets/plugin data of Synchron Smart Orchestra created with this version.
Create backups of important projects/templates before rolling back to an older player version.
Fixed
• Copy/pasting a slot would potentially alter the parent node's node crossfades
• Erroneous node index when moving dimension controller via mouse
• Possible exit crash because of dangling NKS notification
• Broken NKS lights
• Broken "clear command in context menu of folder nodes
• Changing slots will now leave repetition index intact
• On mixer preset (re)load: If either the old mixer state or the mixer preset contain a NONE output assignment, the new output assignment from the mixer preset is loaded for this channel. Other than that, the behavior remains unchanged (i.e. output assignments are cached).
• Mixer strips: fixed disappearing labels
• Flow View: Wrong keyboard play range when loading samples on MIDI activity
• Sound Variations: Update FLOW UI on SV changes
• Sound Variations: Corrupt 'sound.path" entries in ** keyswitch" files fixed (character limit was reached, we're truncating in such cases)
• Sound Variations: Set active nodes correctly if Dimension Controllers/CCs are used
• AUv3: now also works with more than 8 channels
Improved
• Mixer strips/AUX: Improved performance on silent mixer channels
Changed
• Attention macOS: Big Sur (11) is the new minimum system requirement
Tracktion BioTek 2 updated to 2.3.9
No idea what the changes are. The product page is now for BioTek 3 which is $99 upgrade from BioTek 2. Not sure it's worth it for me.
Run Tracktion Download Manager to update.
Audio Hijack updated from 4.4.7 to 4.5.0
Updated in Audio Hijack 4.5.0:
Major “Transcribe” Improvements
Several notable improvements have been made to Audio Hijack’s “Transcribe” block:
• Thanks to the power of Metal (Apple’s high-performance graphics and compute API), transcription processing is now faster and more efficient on supported machines, including all Apple Silicon-based Macs!
• An issue where transcripts featuring multiple participants could occasionally misidentify the speaker has been corrected.
• The “Beta” label has been removed. “Transcribe” is now fully supported.
The “Transcribe” template, found in Audio Hijack’s “Template Chooser” window, now cleans up audio before feeding it to the “Transcribe” block.
- corbo-billy
Komplete Kontrol updated to 3.4.0.
Komplete Kontrol updated from version 3.3.4. to 3.4.0. _
Update via Native Access .ADDED Integration of Partner Hardware (Akai Professional, M-Audio, Nektar, Novation and Korg)
ADDED 3rd-party hardware product tag filtering
ADDED Parallel plug-in scanning
ADDED Ability to load MP3, MP4, FLAC, OGG
ADDED Show controller mapping help guide
ADDED New notification widget in the Browser and MIDI Template view
ADDED Preference option to opt out of using specific plugin formats (only for VST3, VST2 will follow for Intel systems)
ADDED MIDI learn and 3rd-party hardware browser in separate tabs
ADDED Can now use native macOS close button for Komplete Kontrol standalone
ADDED Kontrol S MK3 keyboard connection compatibility updated
FIXED Minimising and maximising Komplete Kontrol with Massive X hosted in Windows leads to graphical glitches
FIXED Tempo label in the header is visually offset in plugin
FIXED Browser window is cropped sometimes when reopening plugin
FIXED Third-party plugins could start at the wrong size
FIXED A crash that would happen in some cases where users did not have plugins to load in Komplete Kontrol
FIXED Quick browse fixed for all supported keyboards
FIXED Fixed several plugin UI layout bugs
FIXED Sampler and Audio Plugin waveform display is incorrect colour
