Show/Hide Track Selector in Sequence Editor Not Working
dwilliams
Post by dwilliams »
Why does show/hide track selector in the Sequence Editor no longer work? Does anyone else have this problem?
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
Re: Show/Hide Track Selector in Sequence Editor Not Working
dwilliams wrote: Sun Feb 09, 2025 12:42 pm Why does show/hide track selector in the Sequence Editor no longer work? Does anyone else have this problem?
Just used it without issue.
EDIT: I use the SE in Consolidated Windows.
https://rbohemia.com
If you are talking about microscopic button in the lower left corner that shows/hides the track selector-- we've kind of settled on the idea that the button works, it is just a very small click zone, and one can easily miss it when trying to see it, much less click it. I think some Themes show it more clearly than others (?)
If you are talking about some COMMAND that shows or hides it, then I don't know about that.
Phil O
Post by Phil O »
I have resorted to always using the key command since trying to find the click zone is an exercise in frustration. Yes it still works but I can understand how you might think it doesn't.
This is a mystery to me. I have no problem seeing or clicking on the image of the track selector at the bottom left corner of any of the screens. It can be selected in the drop down menus in any of the panels in the sidebars, and invoked with Shift-Command-T.
Could it be a problem with some themes?
Or, a shot in the dark —- I stopped using a bluetooth mouse with DP and design apps. I found the BT latency led to some problems when trying edit quickly, narrowing on exact spots on the screen etc.
bayswater wrote: Mon Feb 10, 2025 7:59 am Could it be a problem with some themes?
I recall that some screenshots showed that indeed some themes had windows with more rounded corners, which made that button harder to see & click.
stubbsonic wrote: Mon Feb 10, 2025 8:18 am
Maybe an edit on the image would help. It helped in the past with the velocity marker problem.
E.g., is this much different from what most are seeing?
Image 2025-02-10 at 9.32 AM.jpg (45.25 KiB) Viewed 2465 times
