DP 11.33 not showing inputs from UAD console.
ross
Post by ross »
I'm using DP 11.33 on a Mac mini M4 and an unable to get DP to see input from my new Apollo Twin X. I suspect the problem is with the UAD console as there was no problem with my older twin.Does anybody have any Idea as to why this may be happening?I've been unable to solve the problem despite hours of research on line.
ross
Re: DP 11.33 not showing inputs from UAD console.
Post by ross »
Correction.This topic should read.
DP 11.33 not showing audio (input) from UAD console.
The UAD web site shows an audio installer that needs to be run but doesn’t indicate that it includes a driver. Have you done this?
For any 3rd party drivers and extensions to be installed over Apple Silicon, your Security Settings must be changed.
https://support.apple.com/guide/mac-he ... 8f7291/mac
You may have to reboot multiple times during the process and after installing the driver with a new acceptance screen each time. Click OK on all of them.
This should do it. If not, get a USB4 cable. The good ones are backward compatible to USB 3.2/2/1.1 and Thunderbolt 4/3 (and TB 2/1 with the Apple adapter). Avoid “Intel Certified” TB3/4 cables. Although based on the USB4 spec, they often don’t support anything else. I solved a problem with my wife’s school rig this morning by swapping out just such a cable. This cable should include my review that I verified backward compatibility.
https://www.amazon.com/gp/product/B0D6 ... =UTF8&th=1
