Remove blank bars from beginning of song • RESOLVED
apanacci
Post by apanacci »
Hey guys cannot remember how to do this. I have a song that starts at bar 32. Nothing before that, just blank bars. How do I cut time so the whole song starts at bar 1 or 2 ? In Protools there is a function to "cut time". Does DP have that , thanks !
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Remove blank bars from beginning of song
Snip, in Edit Menu or Command J
apanacci
Post by apanacci »
Wow that was easy! Thank you sir !!!
apanacci wrote: Sun Jan 05, 2025 9:13 am Wow that was easy! Thank you sir !!!
:D
Irimi Nage
Post by Irimi Nage »
HCMarkus nailed it so I will add a supplemental note.
Be very careful to mind your conductor track data when doing this.
I would also advise making a duplicate backup of your sequence before doing this.
DP, for years, has been a little spotty on performing Conductor Track operations with 100% reliability. Usually it's fine but I'll typically just copy/paste the current sequence in the chunks window (not duplicate sequence, they don't do the same thing) so I can go running back to the unaffected original if need be.
One of the issues to look out for is DP creating incomplete bars in the timeline. That can really screw things up. It doesn't happen that often. Unless I'm doing a lot of Conductor edits, that is lol.
