renderSlice 1151 -10876 Error
bdr
Re: renderSlice 1151 -10876 Error
Post by bdr »
I had the same error trying to open Rob Papen's Predator in DP11.2, on Monterey on my new Mac Studio. I emailed Rob Papen support who got back to me very quickly, saying that it's a sidechaining issue. They got me to open it up in a different DAW, turn sjidechaining off, save, and then try to reopen in DP. Still didn't work. However, I was able to open it inside Prisma, which is Papen's own host that opens as an AU in DP.
They have also sent me a beta to try to see if it fixes it.(haven't tried yet). Supremely helpful company.
You could try opening affected plugins in a similar plugin host in DP, like Bidule.
bdr wrote:You could try opening affected plugins in a similar plugin host in DP, like Bidule.
Also Blue Cat Audio’s PatchWork will do this too. I’ve used it to open FM8 directly in DP as well as DrumCore 4 without having to run DP in Rosetta.
dtobocman wrote: Sat Oct 15, 2022 9:58 pm I'm having the same problem using Reaktor. Komplete Control gets around the problem, but I don't have the full functionality of Reaktor. It only loads presets, which then loads each of the different synthesizers (ensembles) within Reaktor, but it's not how I'm used to working with Reaktor. Ugh. I go to Reaktor to get weird and this feels like I'm auditioning keyboards at Guitar Center. This looks like it could helpful to get me back to my normal Reaktor enviroment:
https://support.native-instruments.com/ ... TE-KONTROL
I'm not sure if you saw my reply. I hadn't had time to try it myself tonight, but I made a little screen capture movie. Is this what you need? I'm not familiar with Reaktor, but if you choose "View > Edit" in Komplete Kontrol you will see more of the Reaktor GUI including an EDIT button that appears to allow you to access deeper functions. See the movie below. (Click the title of the video to watch it larger at the YouTube site).
Jim
Post by Jim »
I just got this error on my new Mini M4.
Looks like my installations of Kontakt are not remembering the Content Location. I've changed it three times in the last 24 hours from my old SAS RAID to my newish QNAP NAS.
I've reinstalled the whole Kontakt Komplete library two times, because Relocate doesn't work.
I'm trying to reinstall again, and most of the reinstalls are resulting in "Installation Failed."
What version of Kontakt are you using?
Jim
Post by Jim »
James Steele wrote: Fri Dec 20, 2024 3:06 pm What version of Kontakt are you using?
Komplete 13, which shows in my signature that I now see I haven't updated for the new computer or DP 11.33. Sorry about that.
I'm still shaking down the M4 to see if I'm ready to abandon the MacPro yet. I have a couple of deal-breaking issues I'm trying to suss. This issue with Kontakt is just an annoyance at this point.
Jim wrote: Fri Dec 20, 2024 6:24 pm
Not sure I remember what version of Kontakt comes with Komplete 13. I'm guessing it's Kontakt 7 then? Most current version is 7.10.7 which was updated not that long ago. Just wondering if you're on that version?
Jim
Post by Jim »
James Steele wrote: Fri Dec 20, 2024 11:38 pm Not sure I remember what version of Kontakt comes with Komplete 13. I'm guessing it's Kontakt 7 then? Most current version is 7.10.7 which was updated not that long ago. Just wondering if you're on that version?
I think it came with version 6, but I've been using 7 for two or three years. Version 8 is compatible, and I upgraded, but it takes a long time to initialize, so I unlisted it (or whatever they call it) to remove the temptation to invoke it.
I successfully Relocated or Reinstalled most of my Kontakt instruments last night. I'm hoping they'll be remembered this time.
Native Access is lying to me about the Content Location ("Path is invalid") where I'm telling it the libraries are, and has refused to reinstall two VIs - "Installation Failed." I followed the help link, did what I'm told, no help.
I guess I just can't use those any longer. One is Previews, which can be helpful, but alas. The other was a paid upgrade (Acoustic Legends), so I'll have to take that up with NI.
Now that I've got most my Kontakt VIs authorized again, I haven't seen that message re-occur. My inference is that if you have a damaged or incompatible Kontakt VI in an existing project, that will induce the message in the thread title. That's pretty much what the general consensus is here on this thread.
Perhaps related, although I haven't seen the specific error code, Battery 4 repeatedly not finding content was resolved by removing the Battery plug in completely, then adding it back to my template.
