828es avb with 24ai
tyrone22
828es avb with 24ai
Post by tyrone22 »
Hi,
Having trouble with the direction for setting up 32 input avb setup with 828es and 24ai.
I'm following the setup directions for the 16a and 24ai.
https://motu.com/techsupport/technotes/ ... avbdevices
In the setup instructions it said to set mixer to and to and from computer to zero but it default to 2 to and from computer setup..
All I'm trying to have is 32 inputs 8 from 828es and 24 from the 24ai..
With one set of monitor outputs and 2 sets of headphones.
Do anyone have clearer instructions or preset that they can post..
Thank you
Re: 828es avb with 24ai
Note that whichever device (I'll call it "Master") is connected to the computer must have steams TO- and FROM-COMPUTER enabled.
The device connected to the Master is the one where the Computer connection number should be zero.
Maybe try one of the Preset Files...
Hope that helps.
tyrone22
Post by tyrone22 »
Thank you I will try again in the morning!
tyrone22
Post by tyrone22 »
I believe i have it setup the way you describe but the 24ai input and outputs won't me zero out?
You might want to reach out to MOTU directly to get this resolved.
tyrone22
Post by tyrone22 »
Yes i have a ticket in.. thank you
