How to Update 828 Mk 2 firmware from 1.00 to 1.01
Re: How to Update 828 Mk 2 firmware from 1.00 to 1.01
Jez_Wright wrote: Fri Feb 12, 2021 7:19 pm Ahhh right I get you. So basically need a Mac pre-2006 to run the file... Is there any way to do a firmware upgrade with a modern day mac?
I see G4s on Craigslist for $25–$50 or so.
mothra
Post by mothra »
Ive got a Yikes 350Mhz, a dual 450Mhz, and an upgraded QS2001 with a dual 1.4Ghz in it, plus a blue and white G3, a dual core G5, and Ive got a 1.01 828MK2 for sale. I should set up a shop for jobs like this haha.
M2 Pro Mini, macOS 15, RME Digiface USB/Ferrofish Pulse 16 x2
c3pop
Post by c3pop »
Jez_Wright wrote: Fri Feb 12, 2021 7:19 pm So basically need a Mac pre-2006 to run the file... Is there any way to do a firmware upgrade with a modern day mac?
I've successfully updated my 828 mk2 firmware from 1.00 to 1.01 using the following environment.
- `DownloadFlash` and `828Mk2_1.01.bin` downloaded from
https://docs.google.com/leaf?id=0B2Z-8L ... ZGNh&hl=en
- Mac OS X 10.6 Snow Leopard installed with Rosetta
Note:
+ Rosetta is required to run `DownloadFlash` program on an Intel Mac.
+ Mac OS X 10.6.8 is the last Mac OS release that supports Rosetta for Intel Mac.
- Mac mini (Late 2009)
For the detailed instructions, refer to the original post by drzygote.
drzygote wrote: Sat Feb 27, 2010 11:21 am So here is how:
henris42
Post by henris42 »
Same here,
The instructions are still valid after all these years. I used also Snow Leopard, but I installed it to a "Hackintosh". (A 2012 Intel i7 "Haswell") - bit hacking to get it installed, but no issues at all with the PCI FW card and the firmware upgrading. I guess I'll try to install old Digital Performer to it, to have bit of a flashback.
