which is better with the latest version of dp?
what are my minimum requirements? using tax refund to buy a new used mac. currently using a g4 single 533. not cutting it..would like to spend under a grand for a new rig including monitor. thanks
g4 dual or g5 single?
- giles117
depends upon which dual g4
I upped a system from a dual 867 to a single 1.6 and DP is wonderful on that rig....
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
Euphonix MC Control
I heard from a very reliable source that anything EXCEPT the single 1.6 GHz will show a significant performance improvement from a G4.
Reason being: the single 1.6 was the first G5, and most of the internal bus architecture is the same as a G4. That chokes down most of the performance improvements the G5 is supposed to give you.
Shoot for a single 1.8 GHz or higher.
Paul Bordenkircher
Mesa Sand Productions
Music Services for Independent Artists
www.mesasand.com
paul@mesasand.com
Dual 2GHz G5 / 1.5GB / 80GB/150GB HD, DP5.1, Motu 828 Mk II, 828, M-Audio Octane, dbx 266XL, Behringer MIC2200, Tannoy Reveal Actives, SonikSynth 2, SampleTank2
www.mesasand.com
paul@mesasand.com
- giles117
Problem with that assesment is they were comparing it to a Dual 1.42 G4. If he has a Dual 533 and wants to upgrade, a Single 1.6 G5 is just fine.mesasand wrote:I heard from a very reliable source that anything EXCEPT the single 1.6 GHz will show a significant performance improvement from a G4.
I have a single 1.6 (check the signature) and we use it to run reason Dp 4.61,Logic 7 etc.. runs just fine we added a 2nd drive to it for performance and the unit runs great... Much better than my Dual 867 G4, also the G5 .6 has PCI-X if I recall which was not available in a G4....
Also the buss speed was FASTER than A g4 so if the architecture is so similar they messed up in a few areas, eh?
DP 6.02
Euphonix MC Control
Euphonix MC Control
