McDSP Plugin Updates
https://mcdsp.com/downloads/plugin-downloads/
Looks like all their software plugins had a version upgrade since yesterday. They went from 7.2.25 to 7.2.30
Steinberg Updates
Steinberg Updates
If you launch Steinberg Download Manager today, it will update Media Bay Server to 1.2.10.24 and Steinberg Activation Manager to 1.5.3.1212.
Tracktion/Wavesequencer Updates
Hyperion 1.60 updated to 1.6.1
Theia 1.17 updated to 1.18
Run Tracktion Download Manager to update
Korneff El Juan Limiter - Updated to 1.0.4
https://korneffaudio.com/my-account/downloads/
El Juan Limiter
Version 1.0.4
10/21/2024
- fix input trim level
- Add Global Settings panel
- Add User definable key commands
- add Tempo Sync Release to automation
- change font size and color on GR meter
- add clickable Dither and Resolution sliders
- Hi/Lo toggle grayed out when Dither is Off
- move stereo width before limiter
- many advancements to License Manager
- (PC ONLY) change installer zip type to prevent false-positive virus detection
Note: The installer leaves the PDF Manual on your desktop when it finishes.
Korneff Puff Puff mixPass - updated to 1.0.1
Puff Puff mixPass - Changelog
Version 1.0.1 - Released 10-22-2024
- Selectable Flower Image: Added the ability to choose different flower images within the plugin.
- License Manager Update: Improved the license management system for smoother activations and better error handling.
- Global Key Modifiers: Introduced global key modifiers to enhance user customization and control.
- Preset Browser: Updated the preset browser for faster and more efficient preset loading.
- Onboard Manual: Fixed an issue where the onboard manual was not installing to the correct folder.
T-RackS 6 MAX updated to 6.1.0
May apply to the versions. This is just the one I have.
New module: Triad Chorus
Modules: improved compatibility with Cubase on Windows
Modules: improved graphic rendering on some modules
Modules Manager: modules visibility is now preserved when installing a new update
Channel Strip X: improved automation parameter names readability
EQual: resolved an issue where filter type names wouldn’t always render correctly
EQual: resolved an issue where band handles could get stuck in certain positions
EQual: resolved an issue where activating the Linear Phase option could alter the filter shape on the left channel
Fame Studio Reverb: added missing connection for the Position parameter
Fame Studio Reverb: resolved an issue where the 360 logo would appear when Plate is selected
Sunset Sound Studio Reverb: improved rendering for the Plate and Spring images
Sunset Sound Studio Reverb: resolved an issue where the 360 logo would appear when Plate or Spring is selected
Master Match X: improved analysis process reliability when audio is not being processed by the host
Master Match X: resolved an issue where loading custom References via drag and drop could fail
Mastering Console: resolved an issue where the Assembly toolbar wouldn’t always be accessible on Windows
Mastering Console: resolved a mismatch in the fade-in and fade-out selectors in the Waveform panel
corbo-billy
Post by corbo-billy »
Altiverb 8 MAX updated to 8.1.0 :
Improved support for Third Party and User Creaded IRs in the IR browser
User Created and Third party IRs can now be added to the Favourites (and Favourites can be removed too).
AU: 7.1 and higher output configurations work now
Added import/export of presets (imports also from v7)
Added import/export of the contents of all snapshots
Added functionality to download of new IR sets from the IR Browser
updated Screensaver
updated IRTool.app
many small improvements & fixes .
Classic level meters in the mixer tab
Import and export of single presets or entire snapshot banks
New IR downloads from within the browser window
And a new IR for thid update:
https://www.audioease.com/altiverb/
IK Multimedia MODO BASS 2 update to 2.0.4
Changes from version 2.0.3:
• Minimum required macOS version is now 10.13
• Reduced installer size
• Fixed an issue where the plugin version would appear blurry on Windows when DPI scaling is higher than 100%
• General reliability improvements
8DIO Soundpaint updated to 3.2
https://soundpaint.com/pages/free-engine
apulSoft Updates
apulSoft Updates
https://apulsoft.ch/
Note: PDF Manuals are updated too, so download those also.
apUnmast updated to 1.0.6
This is the first plugin that got updated to Juce 8. This means better UI performance and future-proofing of OS and host compatibility. During the migration to Juce 8, I decided to rework the graphics and use a different (darker) approach for the dark color schemes.
apShaper updated to 1.2.4
apShaper got a new feature: A through-mode for dynamics detection. This allows to use the side-chain as a modulation signal without any extra processing and is especially useful in hosts with modular routing capabilities.
apShaper was moved to Juce 8 and got the new UI treatment.
apVerb updated to 1.2.2
apVerb has been migrated to Juce 8 with the overhauled UI style.
Valhalla SuperMassive version 4 (freeware)
They added a new mode called Pleiades:
"Fast attack, smooth decay, high echo density, filtering in the feedback loop, great for realistic and transparent reverbs."
https://valhalladsp.com/demos-downloads/
Vienna Synchron Player updated from v. 1.3.1836 to 1.3.1865
v 1.3.1865 - November 25th, 2024
Fixed:
• A Synchron Strings Pro update caused issues for Synchron Strings I users
APU Software Updates
APU Loudness Series updated to 3.0.7
https://apu.software/download/
Version 3.0.7
Fix file load deadlock during analysis (meter/optimizer)
Raster shader improvement
Logo update
APU Loudness Series updated to 3.1.0
Version 3.1.0
Dry/wet parameter (limiter)
Change AUTO panel layout (limiter)
Fix threshold rendering for ceiling < threshold (limiter)
Smoother history animation with large buffer sizes
Support custom panel and meter textures via theme tab
Kontakt 7 updated to 7.10.7
Run Native Access to update.
Version 7.10.7 2024-12-02
ADDED
Support for macOS 15 Sequoia
IMPROVED
Now loads as much as 6x faster than prior - better instantiation times with a lot of content products and 3rd
party plugins installed
IMPROVED
Tool-specific presets or multis that require Kontakt 8 are now hidden in Kontakt 7 to avoid confusion
FIXED
Kontakt not properly updating the Kontrol S MK3 Lightguide in certain scenarios
FIXED
When hosting Kontakt in Komplete Kontrol, the Instrument interface could get stuck on the prior instrument despite loading a new instrument
KNOWN ISSUE In Pro Tools, Kontakt window is cropped when zooming
larger than available display size
KNOWN ISSUE
Please note that if you have updated to Kontakt 7.10. from a version before 7.9, you may need to reselect your audio device on first launch (macOS only)
Kontakt Engine/Builder.
FIXED
Missing PV button in instrument header for instruments with performance views
FIXED
KSP Setting SZONE_PAR_VOLUME was incorrectly clamped to 31.02 semitones
FIXED
KSP Regression in load_array behavior when loading string arrays (since Kontakt 6.7)
FIXED
KSP Regression where SENGINE_PAR_LR_SWAP and SENGINE_PAR_PHASE_INVERT did not point to Inverter effect in instrument busses (since Kontakt 7.2)
IMPROVED
Warnings are not shown as errors anymore in Creator Tools Debugger and Kontakt Lua API terminal
ADDED
API factory_snapshot_path and user_snapshot_path entries in the Instrument Options table
FIXED
API set_group_start_options) now properly obeys the given group index
