I have a 1.33 ghz iBook. I've been trying to run DP4 and 4.5 on it. It crashes when I click record or play. I can't see how to increase the ram for the program like in the old days. It is not in the "get info" menu anymore.
I think the Ibook has 256 of ram. Perhaps that is too small. .
Does running DP on an iBook have it's own set of requirements?
256 ram, 60 gig HD, 10.4OS.
I see I have to learn a new set of keystrokes.
Cubase LE seems to run fine (Came with my Alesis Multimix).
I've been running the program on desktop systems since 2.6. On my desktop i run 4.6 on a 2gig dual G6, 1.5 gig ram. Smooth as can be.
Any info would help.
Trouble running DP on 1.33 iBook
- alobonzo
Hi Patricdeimon
You should put more Ram in your machine, it really makes the difference, at least 1 Gb more.
Also update your DP version to 4.52, I know that with your actual
version preferences are corrupted by Tiger, as mine were, and I had to update.
Good Luck
DP is CPU and RAM hungry!!!
Good Luck
PB G4+Presonus Firestudio+DP
iMac Core2Duo + Cubase4+Toneport UX2
Apple Certified Trainer - Final Cut Pro 6
