I’m currently on a 2013 MacPro (Trash Can) running Catalina (10.15.7) and a MOTU 828 Mk 2 (Firewire only) - Driver 1.6.83634 connected with the Apple Thunderbolt to Firewire converter.
All with no issues.
Oh and currently running DP 10 but intend to move to 12 when it arrives.
For other reasons it would be useful to upgrade to Monterey 12.7.5 which is as far as I can go.
So my question is will the 828 Mk2 FW work without issue on Monterey?
What are peoples experiences with it?
And or what hack were needed if any to get it working.
All with no issues.
Steve
If it works for you now, it will work then. No hacks but there are some installation issues to note.
You will find the latest driver under the 828mk3 Hybrid
At some point, DP will ask for access to the microphone. You must grant this—even though your 6.1 doesn't actually have a microphone. It's no longer automatic.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
Make sure that the cable you use supports USB 2/1.1. There are USB B to USB-C Printer cables on Amazon that support this since not all USB 3 cables do.
