DP11 - Clear Babylon Waves Artconductor articulation map?
soulbill
Post by soulbill »
Hi all,
Is there a way to clear the articulation maps in DP11?
I'm using DP11.3.2, and I'm in the middle of two project with impending deadlines and need to just clear the articulation maps and go manually (keyswitches) until I figure out a set of problems I'm having. Surely this is a me problem: I'm still getting used to articulation maps and I'm a recent user of BabylonWaves Artconductor. But suddenly five days ago Sptifire Audio plugin instruments changed behavior with DP11 when using Babylon Waves Artconductor. While I figure out the problems, I need to keep working. These are not Kontakt instruments. The problems appear to be isolated to the Spitfire plugins for Abbey Road 2 Strings and BBCSO Pro. While I'd ultimately like to fix this, I don't have time to mess around anymore.
Please, can anyone help me out? Is there a way to clear the articulation maps in DP11, or is there another workaround?
My setup:
Mac Studio (2022), M1 Ultra, OS 12.7.6
DP 11.3.2 (current)
Spitfire Audio Abbey Road 2 Strings and BBCSO plugins
Babylon Waves Artconductor (FYI, I downloaded current version 10, but I'm not sure if it installed properly and updated?)
{Note: I crossposted this in a VI Control forum as well}
Thank you.
www.WilliamCampbellMusic.com
Mac Studio Ultra 64 GB | MOTU 828es
DP | Finale | Kontakt | maybe too many libraries | etc...
Yamaha C7 | Hardware synths | Stringy plucky things | Some wind things | Preamps | mics of various flavors | etc...
Re: DP11 - Clear Babylon Waves Artconductor articulation map?
R-click Move to trash?
soulbill
Post by soulbill »
SOLVED -
There's a selection for "None" at the top of the window for the Articulation Map Setup. I clicked that selection and the articulations cleared.
In the words of Rosanne Rosanna Danna, "Never mind!"
Now to get back to work, gradually find a proper solution to the issues, and go back to lurking in the forums...
soulbill wrote: Sun Aug 18, 2024 1:24 pm SOLVED -
Thanks Bill!
labman
Post by labman »
Glad you found 'none' Bill.
It would be great if we could wipe the art mapping from all tracks in the piece at same time though. (Unless i am missing something that is already available to us)
