T-Saturator is a smart level-independent saturation plug-in that gives you precise control over your track’s tone and character. Whether you’re looking for subtle warmth, enhanced dynamic range, or screaming distortion, T-Saturator will get you there with ease.
The YouTube video doesn't really have any audio examples. You can download it and try it out. Also keep in mind that developer doesn't seem to have a proper installer so you have to drag the .component file into your Components folder. This will result in the plug being "quarantined" and it wont pass validation. So prior to launch DP you will have to fix this issue using Terminal as described in this post.
OCEAN PLATE : Analog warmth, limitless creativity !
May 17
Introducing OCEAN PLATE – the epitome of warmth, depth, and sonic excellence in the realm of digital audio processing. Crafted meticulously from a stunning analog device renowned for its unparalleled sonic character, Ocean Plate reverb plugin takes your audio to breathtaking depths, enveloping it in lush, immersive ambiance reminiscent of vast, shimmering oceans !
With its rich, warm sound, Ocean Plate is not just a tool ; it's an experience. Whether you're producing music, mixing tracks or designing soundscapes, this plugin infuses your creations with an unmistakable analog charm that sets them apart.
But Ocean Plate isn't just about reverb ; it's a complete sonic sculptor. Featuring a meticulously designed EQ section, you have total control over shaping your sound to perfection. Whether you're dialing in subtle enhancements or completely transforming the character of your audio, Ocean Plate empowers you to achieve your sonic vision effortlessly.
Ocean Plate brings the unmatched quality of analog reverbs within reach of every producer, musician, and sound designer.
The description is pretty fascinating-- (IMHO, more fascinating than the sounds themselves). But still it's an intriguing idea and looks well executed. I didn't download, so I can't vouch for it.
Heck... I have the full Ozone 11, but I might try to get a license for this one, because I have Ozone 9 Elements and as I recall the CPU hit on Elements was lighter than the full version.
(Be forewarned... they require your name and address and email to send you the link.)
We are thrilled to introduce our latest plugin, the Techivation
T-De-Esser 2— It is FREE!
In July 2021, we released our first audio plugin, the T-De-Esser, which quickly became a favourite among many professionals. To celebrate the third anniversary of the T-De-Esser and Techivation’s entry into the audio software world, we are excited to offer you our brand new T-De-Esser 2 plugin.
T-De-Esser 2 addresses harshness and sibilance issues even more naturally and musically than the T-De-Esser. It enhances the overall mix in a gentle, pleasing manner and can be used on individual tracks, group tracks, or the master buss without causing undesirable effects or artefacts.
The entire DSP algorithm in the T-De-Esser 2 has been upgraded, and it is equipped with additional features. The plugin also boasts the brand-new MK2 user interface from our T series, enhancing workflow and making it more user-friendly.
Ok, free, sure, so I did it.
Well, this was a surprise. Normally, when I install Ozone, Elements and Advanced of any version, whichever I install last works and the other two are unavailable in DP. This has been true ever since the iZotope Product Portal happened again when I allowed NI to install my copy of Ozone 10 (the standard version installs with Ozone Advanced anyway so there's no point).
This has changed with 11. As you can see, the freebie installed alongside the Advanced plugs and there's Standard sitting at the top. Although I do have a copy of Standard in one of my packages, I'm leaving well enough alone.
For kicks, I tried it on Rachmaninov's Rhapsody on a Theme by Paganini with the composer at the piano— 1941 in glorious lo-fi mono. No, it cannot perform miracles but it was fun to see what was possible. It's in 25 parts on my CD, not a problem, but on my iPhone, it's 25 separate pieces so I dumped it into DP awhile back so that it will play back as a single piece in iTunes.
Screenshot 2024-07-08 at 11.38.50 AM.png (177.38 KiB) Viewed 2902 times
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
Well, this was a surprise. Normally, when I install Ozone, Elements and Advanced of any version, whichever I install last works and the other two are unavailable in DP. This has been true ever since the iZotope Product Portal happened again when I allowed NI to install my copy of Ozone 10 (the standard version installs with Ozone Advanced anyway so there's no point).[/quote]
Yeah... I'm not sure how, but I was able to have Ozone 9 Elements and the full version installed at the same time at one point. I still have Ozone 9 Elements installed.
Unfortunately (and I think I posted about this in the Plugin "Deals" topic), the CPU savings of the Elements version versus the full version that was there in Version 9 isn't very dramatic in Version 11. Details are in that post here: viewtopic.php?p=613048#p613048
Ozone 11 Elements only saved about 3% on the CPU hit versus the full version of Ozone 11. Oh well...
An 8 layer vector "oscillator" with harmonic pitch control
Multimode harmonic filter
A flexible selection of modulators with LFO, envelope, table, step sequencer and gate sequencer modes
Diverse sound library sourced from vintage synths
SFZ, WAV and AIF import
I infer from the various pages that this is still in development, and will have some bugs; and that there is or will be an "expanded" version which appears to have a name-your-price field. There also appears to be a sibling product called Xolotl which you can view by clicking the "Brother Synth" link on the github page.
I love the color scheme and graphical elements of the GUI.
I tested it and it worked as of 12:25pm PDT. It changed the price to FREE. Just don't bother adding the free gift when you put it in your cart, because it will be removed when you enter the code. I would have jumped on myself, but already have them.
