Update: I'd jump on this if you don't already have it. I added Nova to my cart at AudioDeluxe and discovered the added UVI Digital Synsations Vol.1 to my cart for free! I think I have it already, but usually they send a code that you can give to a friend, etc.
On sale right now at AudioDeluxe:
https://www.audiodeluxe.com/products/au ... ns-edition
NOVA GE is a parallel dynamic equalizer. Appearing in the familiar layout of a parametric equalizer, the plugin also includes a full featured dynamics section enabling NOVA to cover an impressively wide range of applications. Be it a master lacking density, the drum bus asking for more crispiness, or a sibilance problem in your perfect take: NOVA has an elegant answer.
A user friendly WYSIWYG drag and drop display paired with a classic “knob” interface gives quick and smooth access to the various parameters driving NOVA’s powerful signal processing. Elaborate equal loudness functions help finding the optimal setting without getting distracted by loudness differences. An extensive set of “Smart Actions” automatically generate sensible starting points according to the input; and further allow matching the spectra and dynamics matching of two different songs, approximating a pink noise distribution, or automatically finding and taming excessive resonances in recordings.
NOVA GE includes a total of six dynamic EQ bands, each featuring high grade filters and independent dynamics processors being able to operate in linked, split, or various other configurations.
Use-cases:
• Parametric equalization
• Dynamic equalization
• Frequency selective compression/expansion
• Multiband compression/expansion
• Wideband compression/expansion
Features added by the Gentleman’s Edition (GE):
• Smart Actions: Match Pink, Deresonate, Spectral and Dynamic Matching, Auto HP/LP and more
• Two additional bands
• Dynamics with expansive ratios
• Ability to unlink the SC bandpass from a band’s own bandpass (e.g. trigger HF expansion by LF events, etc)
• Wider Q range and steeper filters up to 120dB/oct
• Support for equal loudness workflows (EL trim and EL bypass)
• High quality modes “INSANE”, “-PRECISE” and “-INSANE”.
• Release automatism can be switched off
