Just went to edit my automation data in a project in latest DP11.32 . In projects spanning a couple years but have been edited in DP11 -Volume automation plays back, as well as pan, but won't show in sequence editor or MIDI editor as data, lines/bars/ points. Nada. Anyone else have this problem? Automation is enabled globally. Modulation does show when recorded and drawn , volume automation shows in audio tracks. Tried in a new project with only 1 MIDI track, no plugins or instruments- same. Records and plays back automation , vol and pan but won't show when selected or w/ show lanes , if insert selected- only mod is an option, others are greyed out . Any ideas? Is this a bug? I reloaded DP. Otherwise everything else running amazingly well with a lot of libraries, loads of pluins.
Mojove, 10.14.6 96 gigs, macpro 2 x 3.33 ghz 6 core Intel Xeon
DP11.32 Automation Data won't show in lanes but records and plays back - RESOLVED
Re: DP11.32 Automation Data won't show in lanes but records and plays back
View Filter?
Yes, after mulling over trying to get to sleep, it occured to me. Turned off in an update, I don't know. Thanks for response. JL
Re: DP11.32 Automation Data won't show in lanes but records and plays back - RESOLVED
I'm having a similar issue. I wrote CC19 automation to the DS Thorn VI and it is working. But in the MIDI Window I can't find a way to view the CC19 data. I read this and checked my View Filter and every box is checked in GLOBAL . If i go to Event List I can add CC19 or click ALL and it does show up in the Event List but I certainly don't want to edit it there? What am I missing?
