apulSoft apShaper 1.2.2 updated to 1.2.3
Tokyo Dawn Labs VOS SlickEQ GE 1.3.8 updated to 1.3.9
Plugin Alliance DS Audio Thorn 1.3.2 updated to 1.3.3
Plugin Alliance doesn't make it easy to find out what's updated. Every so often pull up PlugInfo on one side of my screen and filter "Plugin Alliance" and then log on to PA's site and scroll though my list of licenses and check current version numbers.
So DS Audio Thorn was updated to 1.3.3 recently. I do not know what has changed.
Re: Plugin Alliance DS Audio Thorn 1.3.2 updated to 1.3.3
With Plugin Alliance, go to any product's individual page and scroll all the way down to find the changelog.James Steele wrote: ↑Sun Jun 30, 2024 10:55 pm Plugin Alliance DS Audio Thorn 1.3.2 updated to 1.3.3
- Screenshot 2024-07-01 at 9.16.25 AM.png (224.42 KiB) Viewed 1126 times
Ahhhh thanks, Mike!! Good to know. I’ll hopefully remember that next time!mikehalloran wrote:With Plugin Alliance, go to any product's individual page and scroll all the way down to find the changelog.
Vienna Synchron Player updated from v. 1.3.1263 to 1.3.1463
v1.3.1463 - July 2nd, 2024
Fixed:
• Master channel EQ not reset when loading mixer presets
• Compressor, Limiter and Expander losing sound after copying effect or restarting audio engine
• Limiter make-up gain ignored on bounce
• Possible exit crash
• Possible crash when unplugging iLok key
Added:
• Support for libraries using Lossless compression
• Slot Crossfade Editor
• New Slot Controller: Sequence
UVI Falcon updated from 3.0.2 to 3.0.3
3.0.3
- Support for upcoming product
- Other minor fixes
UVI Workstation updated from 3.1.14 to 3.1.15
3.1.15
- Sync engine features with Falcon 3.0.3
Re: UVI Workstation updated from 3.1.14 to 3.1.15
Well this is strange. I ran UVI Portal and it tells me I need to updated UVI Workstation. I'm used to this because I never update all formats. I use version 3.0.25 for AU and VST2 because it's Intel only. This lets me use older libraries in DP that need to be running in Rosetta to access old iLok authorizations. I digress.James Steele wrote: ↑Tue Jul 02, 2024 12:44 pm UVI Workstation updated from 3.1.14 to 3.1.15
3.1.15
Anyway... UVI Portal is telling me that the current version of UVI Workstation is now 3.1.14! So they pulled 3.1.15??? What's up with that?
No idea. I ran the UVI Portal today and updated Falcon to 3.0.3 but Workstation is still 3.1.1.4 for me.James Steele wrote: ↑Wed Jul 03, 2024 11:02 amWell this is strange. I ran UVI Portal and it tells me I need to updated UVI Workstation. I'm used to this because I never update all formats. I use version 3.0.25 for AU and VST2 because it's Intel only. This lets me use older libraries in DP that need to be running in Rosetta to access old iLok authorizations. I digress.James Steele wrote: ↑Tue Jul 02, 2024 12:44 pm UVI Workstation updated from 3.1.14 to 3.1.15
3.1.15
Weird. I have 3.1.15 installed right now. Actually, I don't think this would be the first time this happened. I believe I contacted UVI about something like this before and they said they released something to correct an issue and then pulled it the next day.mikehalloran wrote: ↑Wed Jul 03, 2024 2:08 pmNo idea. I ran the UVI Portal today and updated Falcon to 3.0.3 but Workstation is still 3.1.1.4 for me.
HALion 7.1.0 updated released today!
There's a new version of HALion released today. I just did a Time Machine backup so I'll give it a go. Run Steinberg Download Manager to install.
Just now ran UVI Portal. UVI Workstation is now version 3.1.15 again. Weird.mikehalloran wrote: ↑Wed Jul 03, 2024 2:08 pmNo idea. I ran the UVI Portal today and updated Falcon to 3.0.3 but Workstation is still 3.1.1.4 for me.
3.1.15
Vienna Synchron Player updated from v. 1.3.1463 to 1.3.1485
v1.3.1485 - July 5th, 2024
Fixed:
• Crash when triggering dimensions with a single slot and assigned continuous controller
• Crash when using time stretching
Eventide/Newfangled Audio Invigorate updated to 1.3.5
https://www.eventideaudio.com/downloads ... Invigorate
1.3.5 (6/26/2024)
ACTIVE button works again
Fixed occasional high gain on start up
