Urgent help needed! Autopan Issues
Hi,
I'm working on a project that I used the Autopan plugin -whipolash on one of the tracks. When I play the mix in the studio or car its sounds fine...when I take it to the church and play it on the sound system...the part with autopan is cutting in and out. Can anyone tell me what could be wrong? At first I thought it was the cables from the CD player...so i bought new chords to go stereo into the system and the same thing happened. I even ran the ipod through the system and the same thing happened. Can anyone help quick...I need to have this done by friday!
I'm playing the track through a cd player whose outputs are going into a yamaha mixer left and right. then of course the mixer outs are going into a power amp to the speakers.
when i use the ipod...i go straight into the mixer....i hope i answered the question right...let me know if you need more info. if there is a phase or polarity problem..i wouldnt know or know how to fix it. Any help is appreciated.
also...when i mixed the track...i did a bounce to audio to get the stereo track. i bounced it down as a wav file.
okay...i'll try again. the cd player has rca outs...so i use the rca to 1/4 inch mono cables (one for the left and one for the right). I also tried using the rca to stereo (balanced) 1/4 cable and got the same result. I'll also try another CD player...and see if that's the culprit.
thanks...i'll let you know what happens.
- philbrown
Re: Urgent help needed! Autopan Issues
Your clues are all right there...csharp35 wrote:Hi,
Since the iPod does it too, it points to the Church system being miswired or just wired in mono at some point in their signal chain. Could be a reversed polarity somewhere even downstream as far as speaker wiring but I bet it's wired or miswired to mono at some point - maybe when it hits the power amps (which can be stereo but bridged to mono for instance). Just a guess based on what you've said.
Some of these systems appear to be stereo, i.e. stereo mixer, etc, but then they Y it to mono or just drop a channel to mono later in the signal chain which would cause what you are experiencing. I'd suggest plugging in left and right one a time to see what that tells you. Also double-check your panning at the mixer on the channels you're using (if that's applicable here).
Afterthought: you could also make a quick test mix panning everything left then everything right to see how the system reacts.
