Detailed instructions on How to route individual drum outputs from Native Instruments Drums in Kontakt to DP.
This forum is being developed and is intended as intended as a place to bring together various Digital Performer video tutorials. Currently only YouTube videos may be embedded using the [YouTube] BB code.
I see tutorials for all major DAW's but none for individual drum outputs in DP.I really need help.So confused!
Re: Detailed instructions on How to route individual drum outputs from Native Instruments Drums in Kontakt to DP.
Virtual Instruments publish their audio outs as busses in DP. Beyond that it's relatively straightforward, inside Kontakt set each instrument to a separate audio output pair and in DP make aux tracks (or audio tracks) that have each of the Kontakt outs as an input. In the menu for the busses sometimes a virtual instrument like Kontakt can be way down on the list so keep scrolling.
I speaking of Sending individual Drum sounds out from from Studio Drummer in Kontakt to individual audio tracks in DP.Can't get it together.Thank you for your help!
Have you attempted to implement Michael's instructions?
Per his recommendation, Add Aux tracks in DP, assign Kontakt Outputs as Inputs to the Aux Tracks. Assign the Aux Track outputs to your stereo bus or drum bus>stereo bus. If you want to record individual drums on audio tracks, assign Aux track outputs to Audio Track inputs, Or you can use Sends on the Aux tracks with Sends routed to Audio Track inputs.Michael Canavan wrote: ↑Wed Jun 05, 2024 7:09 am inside Kontakt set each instrument to a separate audio output pair and in DP make aux tracks (or audio tracks) that have each of the Kontakt outs as an input. In the menu for the busses sometimes a virtual instrument like Kontakt can be way down on the list so keep scrolling.
In my template, I have all tracks (VIs and Audio) routed to subgroups that are routed to the mix bus. Sends on each subgroup are routed to Stem Audio Track inputs, so I can record my stereo mix and all stems simultaneously.
Thank you So much!I'll give it a try!
Wink
Wink
