Go Big or Go Home?
dwilliams
Re: Go Big or Go Home?
Post by dwilliams »
I don't understand this. I tried using a large TV monitor and slowed my system way down and I had to switch back. I wonder why it didn't work out for me. First I tried a 55" LG which was too big as it is right in front of me. Then I tried a 40" (Visio, TCL? I don't remember). It was great. I kept my 25:9 display and set that above the main monitor. But as I said my system slowed way down. I was getting latency on the mouse and DP was significantly handicapped. I switched back and problems solved. I was planning to buy a dedicate Dell computer monitor (I think they are 43" but could be 40"). Maybe I don't need to?
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 16" M3 Max 16-core 4.05 GHz 48GB 1TB Late 2023 MBP, Sonoma 14.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2, TB hub w/ USB 3.0 drives; USB 3.0: Softube Console 1 Mk3, Stream Deck XL; USB 2.0: SSL UC1, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; , M Audio Oxygen 49, Akai MPD218, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.32
Did you set up the TV to work at 60Hz and in Game (low latency) Mode? Otherwise, it is gonna' feel laggy. No reason it should slow down your computer.
My thought exactly brother.
However, he did say his system / DP slowed down as well.
Hopefully it was simply an impression he got due to non-game-mode mouse lag.
dwilliams
Post by dwilliams »
I did try gaming mode (which did improve but not eliminate mouse latency). I did a lot of troubleshooting before I threw in the towel. That is why I'm so confused. All these TVs have very similar specs and a wide range of price points. I wonder if there are some critical parameters that have to be satisfied.
Krakadon
aka Dave Williams
* DP 11.32
I'm using a 43" Samsung 4K TV connected to the HDMI port of my Mac Studio and not having any issues here. I think HC Markus is using a Samsung also. Did you check to see what color profile you are using? I could be completely wrong, but I vaguely remember something about using a particular color profile in the Display settings that could slow things down. Again, though... I may total remember that wrong.
That's very, very odd. Can't figure out why. Are you getting a good refresh rate in the Displays control panel? It needs to be about 60 Hertz to feel smooth.
tremo
Post by tremo »
I've also been using a 43" Samsung 4K TV as monitor for the past few years with no issues. Connected directly to HDMI port on Mac Studio.
One thing to check in System Settings/Displays: Are you using the full 4K resolution (3840 x 2160), not scaling down to a lower resolution? Per Apple: "Using a scaled resolution may affect performance". Have a feeling you already know this, though...
Mac Studio Max M1 | 32GB | 15.3 | 828es | M4 | DP 10.13 | Studio One 7 | Logic 11
dwilliams wrote: Mon May 06, 2024 11:12 pm I wonder if there are some critical parameters that have to be satisfied.
The other key (for response) is to be sure the monitor is running @ 60HZ, not 30. Also, as Tremo notes, native 4k resolution is optimal. You can scale DP itself if necessary.
It is also desirable to set Chroma to 4:4:4 when using a TV as a computer monitor. That must be done within TV, and the specific instructions vary from TV to TV. https://www.rtings.com/tv/learn/chroma-subsampling
HCMarkus wrote: Tue May 07, 2024 6:55 amIt is also desirable to set Chroma to 4:4:4 when using a TV as a computer monitor. That must be done within TV, and the specific instructions vary from TV to TV. https://www.rtings.com/tv/learn/chroma-subsampling
Where did you find this? I think you have a Samsung also? I went to the link and found these instructions:
SAMSUNG TVS
From the settings page, under picture settings, select expert settings. Scroll down to "HDMI UHD color." From here you can select which inputs have this feature enabled. You will have to select PC mode for the input as well.
But I do not have that setting on mine. Hmmm....
Newer TVs may auto-select 4:4:4 when connected to a computer (or so I've read somewhere), but the details are NOT easy to find!
HCMarkus wrote: Tue May 07, 2024 1:51 pm Newer TVs may auto-select 4:4:4 when connected to a computer (or so I've read somewhere), but the details are NOT easy to find!
Ahhh... well I was just curious. Things are working fine here either way.
dwilliams
Post by dwilliams »
I experimented with all the recommendations mentioned here. But I think I notice a theme "Samsung". Maybe I'll try that.
Krakadon
aka Dave Williams
* DP 11.32
dwilliams wrote: Sun May 12, 2024 3:07 am I experimented with all the recommendations mentioned here. But I think I notice a theme "Samsung". Maybe I'll try that.
My inexpensive Hisense is working great, too, just sayin' :D
James Steele wrote: Tue May 07, 2024 12:02 am I'm using a 43" Samsung 4K TV connected to the HDMI port of my Mac Studio and not having any issues here. I think HC Markus is using a Samsung also. Did you check to see what color profile you are using? I could be completely wrong, but I vaguely remember something about using a particular color profile in the Display settings that could slow things down. Again, though... I may total remember that wrong.
This. James is remembering correctly.
Apple defaults to a 10 bit color profile. When everything is lagging, switching to anything else resolves the conflict. I had to do this with my first iMac Pro which surprised me.
darrell
Post by darrell »
Holy guacamole!
