I recently learned that I could put my old 828 MK2 in standalone mode and use an ADAT lightpipe cable to send an extra 8 channels to my Presonus 1810c. After a bit of fussing around, I got it to work, the only problem is that the 828 MK2 doesn't retain the setup when I shut it off. I have to connect to a computer to reload the preset from the Cuemix app every time.
I thought the problem might be the battery, but after doing a little research, there seems to be a question as to whether these units even had a battery? Does anybody have any insight into this matter? Does the 828MK2 have a battery to back up the presets? If not what might be the issue? The MOTU tech tip seemed to indicate that simply waiting a minute for the setup to save before disconnecting the firewire cable was all you needed to do. Thoughts?
828 MK2 standalone mode and ADAT
Re: 828 MK2 standalone mode and ADAT
No battery. It's supposed to remember your setups.
I would shut down the 828mkII first before ending your session in case your computer is sending a message that changes your settings.
The last one of these was made late 2006 ane the rest are older. It's possible that component is no longer functioning.
