Re: UJAM Virtual Guitaist Silk2 and Amber2 updated to 2.3.0
James Steele wrote: Thu Apr 11, 2024 7:09 pm UJAM Virtual Guitaist Silk2 and Amber2 updated to 2.3.0
Thanks for the heads up. I forgot I had those.
Tracktion/Dawesome Abyss updated to 1.3.2
Not sure what the update entails, but just came out tonight. Run Tracktion Download Manager to update.
BTW, for me, the installer downloads the update and just gets stuck and doesn't proceed with the install. You can quit, the Download Manager and then go to your Downloads folder and you will find the update pkg. You can then launch it and install directly.
Then launch Tracktion Download Manager. It will still tell you that you need to update Abyss. Right click the version number and choose "I already have this version" and it will get rid of that.
Slate Digital Heatwave updated to 1.0.3
Run Slate Digital Connect to update.
Heatwave Release Notes
Version 1.0.3
• Fixed AU Crash in Blue Cat Audio Patchwork
• Fixed an issue in Studio One in which the Input/Output parameters of the VST3 version could not be adjusted in increments less than 2dB
Guitar Pro 8.1.2-27 updated to 8.1.2-32
Changelog
Release Notes
8.1.2
Playback
Selections of less than a bar are no longer repeated
Selections beginning with a Slide In are now correctly interpreted
Ornaments are now interpreted regardless of their starting fret
The relative tonality is correctly applied to ornaments
Fixes the score cursor behavior when changing tracks
Fixes the score cursor movement with shortcuts during playback
Fixes some random sound automation changes
The count-in is now correctly updated according to the current time signature
Fixes a count-in triggered when activated during the playback
Edition
The Audio Note Settings dialog is no longer modal
Improves the “Select All” performances in Multivoice
Pasting multiple bars to a selection now correctly moves the score cursor to the next beat
The placeholder is no longer taken into account when using the “Bar Arranger” tool
The auto scroll triggered by a click no longer creates an unwanted selection
Texts and Chronos are applied only if selected in the “Special Paste”
Moving strings maintains the previous accidentals (if any)
Notes created when tying to the previous bar are now correctly undoed
Undoing “Repeat two Bars” now restores the previous content of the second bar
Modifying a note from the Virtual Fretboard preserves its attributes
Undoing the modification of a note from the Virtual Fretboard now works correctly in one step
Fixes the score cursor position after undoing a paste on the last beat
Fixes ties after pasting on multiple bars
Fixes the audio preview of Mordents and Turns
Fixes setting Stems Direction on a selection containing grace notes
Fixes the behavior of the score cursor when clicking on a bent note
Fixes an input error when typing fast in the tablature view
Engraving
Adjusts the slash notehead anchors with the “AMJazz” font
The tempo unit is now correctly taken into account for “rall” and “accel” indications
For minor keys, “1=” is replaced by “6=” in Numbered Notation
Fixes collisions between the “Repeat two Bars” mark and some bar header elements
Fixes the placement of a Bend Release in Standard Notation
Fixes some attributes (HO/PO, ties) of notes bordering a selection after a transposition
Fixes the alignment of diagrams between themselves
Ties between distant slash notes are now correctly displayed
Interface
Notifications on the Welcome page can now be permanently disabled in the Preferences
VU meters in the Drumkit settings popup are now linked to the active sound
Undo is now correctly available on the first action in the Pedalboard and on volume change
Updating the track name now correctly updates the corresponding entry in the “Track” menu
The palette is now correctly updated after tying a beat
The track name in the inspector is no longer selected when double-clicking on the Global View track during playback
The “Add Track” button in the Global View is now correctly disabled during playback
Fixes some cases where the license had to be entered twice
Fixes the movement of the cursor in the Global View bar header when changing tracks
Fixes the Preferences dialog size in case of an unusually long stylesheet name
Fixes empty score info fields when opening a custom template
Fixes some errors in the Time Signature dialog regarding beamings for 16th and 32nd notes
Selections starting with a grace note are now displayed correctly
The tempo in the LCD is now correctly updated when changing the relative tempo
Fixes some translations
Import / Export
MusicXML
Correctly imports the fingering including for a keyboard track
Dynamics are no longer exported in the middle of a chord
MIDI
Fixes the playback after pasting a MIDI file in Guitar Pro
Fixes the import and paste of MIDI files containing consecutive notes with the same pitch
Imports empty MIDI files
Imports the correct amount of bars when the last one is not complete
Audio
Audio export now automatically adds a file extension
Graphique
Fixes how the current time is fetched and formatted for the graphic exports
Audio Track
The cursor movement is now correctly clamped to the bar’s duration
Fixes the visual feedback on hovering the audio track bar and beat lines
Feels are now correctly mapped onto the audio track
The voice index is now correctly preserved when moving the cursor from the audio track
Fixes the zooming behavior
While repitching, the audio track now stays synchronized
Fixes the behavior of the “Add bars” (+) button when the audio track does not have the focus
mySongBook
Reopening the Free Tab of the Day no longer requires to log into mySongBook again
Improves the design of the Expired Trial dialog to highlight the possibility to continue with mySongBook
Miscellaneous
Overall improvement of the handling of audio devices
Fixes the registry key edition for the soundbanks installer (Windows)
Crashes
Fixes a crash on opening a file containing wrong tags
Fixes a crash on refreshing the audio devices in the Preferences dialog
Fixes a crash on adding a note on an empty selection using the MIDI Capture or the Keyboard View
Fixes a crash on adding notes preceded by a Sustain Pedal
Fixes a crash on switching from Grand staff to Single staff with an active selection on the lower staff
Kontakt 7.10.0
YMMV - I can't figure out how to copy the change log.
EDIT!!! Well that didn't take long:
https://community.native-instruments.co ... akt-7-10-0
DSP Quattro updated to 5.9.5
Version 5.9.5: 24.04.17:
⁃ fixed a potential problem loading certain AU Virtual Instruments .
https://www.dsp-quattro.com/dspquattro/ ... tures.html
Re: DSP Quattro updated to 5.9.5
James Steele wrote: Wed Apr 24, 2024 8:38 pm DSP Quattro updated to 5.9.5
Thanks for the heads-up!
Am I the the only one who notices that the app has a smaller footprint than the documentation?
Screenshot 2024-04-25 at 10.04.34 AM.png (560.97 KiB) Viewed 1654 times
mikehalloran wrote: Thu Apr 25, 2024 10:08 am Am I the the only one who notices that the app has a smaller footprint than the documentation?
:rofl:
I hadn’t compared the app to the manual but always wondered how he gets the executable file so small. I remember IT shops that programmed directly in machine code to get small files and quick execution, but wouldn’t think that matters much any more.
MOTU Pro Audio Installer v95330 released April 10?
I just checked for this tonight and not sure when it came out because I think I would have seen it before, but there is a new version of MOTU Pro Audio Installer up in the Downloads section of the MOTU site. It's the first one that specifically lists Sonoma as supported.
Softube Updates
Softube pushed out updates to seemingly most of their plugs. At least all the ones I own. 2.5.82 were updated to 2.5.83
Metric Halo Production Bundle V4 coming soon?
I'm posting this because I ran iLok License Manager and saw that a license for "Metric Halo Production Bundle v4" was deposited into my iLok account today. I'm a registered owner of v3. I guess a version 4 must be imminent?
Arturia Analog Lab V Update
Looks like there's an update for whatever flavor of Analog Lab V you may have. I was on 5.10.0.51 and it's prompting me to update to 5.10.1.4686. Just run Arturia Software Center to update (obviously). :)
Kazrog Updates
Kazrog Updates
Just got a notice in my email that a couple of my Kazrog plugs were updated, so I assume others might have been.
True Iron - Version 1.4.1 - May 1, 2024
Changes:
• Resolved intermittent crash on bounce in Cubase 11/12 on Mac
• Refactored DSP for greater stability and efficiency, consistency with newer Kazrog plugins, with no change in sound from previous versions.
• Added CPU meter to settings panel
• Added CPU overload warning to all plugins when buffer underruns are detected
• When bypassed, plugins will now darken their main user interface to make the bypassed state much more obvious
• Resolved "bypass after bounce" bug in Ableton Live 11/12
True Dynamics - Version 1.2.1 - May 1, 2024
Changes:
• Restored tube bias selection functionality
• Resolved output volume discrepancies introduced in 1.2.0
NI Vintage Organs Instrument Update
That just happened. Went ahead and updated that via Native Access (2 in my case).
