M1 Macbook Pro & Ultralite Ultralite Mk3 or 828 Mk2 non show up in Ventura 13.6 Help PLease
junkmanukuk
Post by junkmanukuk »
Hi
Ive been trying to get the above to show up in Ventura 13.6 for the last couple of days without success
I have the the correct adapters but none of the interfaces will show up ive managed to get them to show up on a Macbook Pro 2013 with Big Sur installed through the Thunderbolt Adapter but not in Ventura
When i have installed the drivers ive never had anything show up in the Security & Privacy preferences maybe thats my problem
Any help would be great
Many Thanks
Re: M1 Macbook Pro & Ultralite Ultralite Mk3 or 828 Mk2 non show up in Ventura 13.6 Help PLease
Start here
https://motu.com/techsupport/technotes/ ... igh-sierra
This has to be done within 3o minutes. If you miss the window, reinstall and try again.
junkmanukuk
Hi
Thanks for the reply does anyone know how to completely remove motu drivers etc to do a clean install as I think that might be the cause of my issues
junkmanukuk wrote: Thu Mar 28, 2024 4:24 am Hi]
Yes. The MOTU Audio drivers must be removed completely before the MIDI drivers are installed over Sonoma. The list of files is found a couple times in this thread.
https://www.motunation.com/forum/viewt ... 9&start=30
It may not be quite that simple, however. Go to page 3 to see my notes on checking the Activity Monitor and other possible conflicts. It can be done.
One thing that cannot be done is to install the Audio drivers onto an external drive connected to an M1/2/3. Apple does not allow some .kxt files to load and there is no workaround (oddly, the MIDI drivers do work on an external—go figure!)...
junkmanukuk
Thxs mike i reinstalled again after deleting all the motu files and folders but i couldnt delete motufirewireaudio.kext and motumicroaudiobook.kext i dont know if that makes any difference
But once again its not showing up and also im not getting
After restarting, open System Preferences.
Select Security & Privacy.
In the Security section, click the Allow button.
Dunno whats going wrong may try on a fresh install
