Sudden high pitch distorted sound: Why is my new interface doing this?
nk_e
Re: Sudden high pitch distorted sound: Why is my new interface doing this?
Post by nk_e »
Joachip wrote: Sun Jan 08, 2023 4:01 am
cfibanez wrote: Mon Aug 16, 2021 6:03 pmBrand new MOTU UltraLite mk5 works perfectly… until it does not. All of a sudden, the sound gets crazy with high pitch distorted peaks. I change the sample rate from 96K to 44K and the audio becomes normal again. Then switch back to 96K and the audio remains normal. (It does not seem to the be a problem with the actual rate that is used.)
Just chiming in to say that I have the exact same problem here with a Motu 16A on a Windows 10 pro 64bit install. (My machine should be adequate, I would believe: AMD 5900X, 32 GB ram, RTX 3070 gfx card.)
I sort of doubt that this is due to a faulty USB cable, considering that changing the sample rate or buffer size always fixes it. My suspicion is that if there's some sort of spike in CPU usage, the computer and audio interface come out of sync, causing the metallic distorted result... until we change sample rate or buffer size, which then apparently forces the driver to resynchronize.
Considering that we hear exactly the same thing, and we do exactly the same thing to resolve it, it seems that this problem exists on both Mac and Windows.
I've just updated my driver from 4.0.8.9612 to 4.0.9.0067, and will report back if the problem goes away. There was no new firmware update for my interface.
Hi.
Just to chime in here. I think Joachim has it pegged.
I use two 16As and an 828ES usually as an aggregated device when not in DP. If I have a “few things going” on (e.g., in a DAW working through a YouTube tutorial perhaps other apps like iMessage or messenger open in the background), it will randomly glitch out as described here. This glitch is almost guaranteed to happen if a notification or other system audio interrupts while working in the DAW and/or watching YouTube. Changing clock rate on my master device or in the DAW always fixes the issue so it’s definitely a loss of synchronization.
My system manifests the problem a little differently sometimes. I will lose sound completely or there is a sudden high pitched whine.
When I’m working on a project, I don’t have a bunch of apps and other things open of course and the number of times the glitching happens goes down a lot … but it still happens. I hadn’t thought to correlate it with a CPU spike, but that makes sense.
It seems to be happening a lot more lately for some reason…
http://www.gesslr.com
Joachip
Re: Sudden high pitch distorted sound: Why is my new interface doing this? - NOT RESOLVED
Post by Joachip »
Why has the topic been changed to "Resolved"? What's the solution?
Re: Sudden high pitch distorted sound: Why is my new interface doing this? - RESOLVED
Joachip wrote:Why has the topic been changed to "Resolved"? What's the solution?
Because original poster seemed to have the problem solved. Apparently it’s a moving target now as others have jumped in. I’m change it back. Image
labman
Post by labman »
I have a few clients with that same problem recently (high pitched squeal), and have experienced it myself from time to time.
Joachip
Post by Joachip »
Oh, my bad. I hadn't noticed that the 5th post on page 1 had been edited with the resolution that replacing the USB cable helped.
Joachip
Post by Joachip »
I replaced the USB cable with a brand new one a week ago, and I think this might have helped, as the glitch hasn't happened for an entire week. But it just glitched out just now, so the problem certainly isn't solved (at least on Windows, that is).
Being a sporadic error, it's hard to tell if the glitch is happening less often now, or if I've just been lucky.
Let's hear if the mac users are still getting glitches too. (Please post if you do!)
Joachip
Post by Joachip »
I had an epiphany just now: I had youtube playing a video, and while it was playing, I turned off my Deepmind-12 synthesizer which is connected over USB. The exact moment when I flipped the switch, the sound went into this high pitched distorted version that this whole thread is about. This is the first time I've seen clear and immediate evidence of a direct cause.
So for those still struggling with this problem: Try noticing if this happens right when you turn off or disconnect a USB device.
M3dicine
Post by M3dicine »
I'd like to add that I have a very similar issue. I'm not necessarily looking for a solution...just to share that I have the same issue and have a more recent post to the thread.
My behavior is that on occasion, I'll get a high pitched tone which will sometimes spontaneously resolve. Upon spontaneous resolution sometimes there is no distortion, and other times I get the same distortion that was recorded in an earlier post. This tends to happen only once and occurs about 1/2h after startup of the audio interfaces.
If the tone does not resolve, or if there is distortion after resolution, unplugging the USB cable and plugging it back in resolves the issue and I cannot remember there being a reoccurrence following unplugging and replugging the USB cable.
I have had some success with the high pitched tone problem in changing USB cables (especially to shorter ones), but none where the issue has completely resolved.
I am having a what may be a separate issue in that I get short duration crackling distortion in my recordings in Audition.
(I can give some examples potentially if desired.) No change in behavior before or after USB cycling. This only happens computer side. I have no distortion to audio direct out of the interfaces...and I never have any issues with audio delivered via analog connectors to the windows box. However, since it seems to be computer side, I imagine it may be occurring during the USB lane processing...which seems related.
Hardware:
2020 M1 Max MBP (14.4.1) -Thunderbolt- dock -USB- 1248
Windows Machine (Win 10 64bit - up to date) -USB- 8M (some audio transferred via analog)
8M & 1248 connected via MOTU AVB switch - (all devices running current firmware/drivers)
Have you reached out to MOTU directly via a TechLink?
Might be worth a try.
https://rbohemia.com
Joachip
Post by Joachip »
Here's a recording of what the glitch sounds like, when it happens on my system:
https://www.robotplanet.dk/f/motu/MotuGlitch1.wav
I'm posting this hoping that it'll help people saying "yes, that's the same thing" or "no, my problem sounds very different".
