MIDI Note Off Not Registering - RESOLVED
westlake79
Post by westlake79 »
Interesting little glitch. When sequencing MIDI, one specific key (C#2) is not recording a note off.
I can play the sample, and when I release the key the sample stops playing but the "note off" message is not recorded into the sequence. At the end of a take I'll get a big long MIDI note on C#2.
This is only in DP, I can't replicate in other sequencers. Any ideas welcome!
DP 11.21
VEPro 7.3.3440
MacPro 28-core
OSX 10.15.7
Re: MIDI Note Off Not Registering
We were just talking about some occasional situation where a MIDI note is assigned to trigger a COMMAND (in the COMMANDS list). In this case, I wonder if somehow the note OFF has been assigned as a command.
A quick way to check this theory is to open then COMMANDS window and turn off the MASTER MASTER and see if that issue persists. If not, then you can try to find what COMMAND has that C# note off assigned. Then just delete the assignment.
I'm grabbing at straws, but hopefully it's simple like that.
westlake79
Nice one, that worked!
DP 11.21
VEPro 7.3.3440
MacPro 28-core
OSX 10.15.7
Were you able to find out which COMMAND had that assignment?
Here's a trick you can use to find it.
1. Choose another command, maybe in the transport section. Maybe "Record" is a good one.
2. Have your MIDI controller ready.
3. First play that C#2 note and keep holding it down...
4. Now click on the field to enter your MIDI event, (it is now listening) now let go of the C#2. You should get a C#2 with an up-arrow.
5. Because DP will warn you if you have entered a COMMAND trigger that has already been used, it should bring up a window telling you where it is used.
6. Now you can remove it from Record and wherever else it was reported just by clicking and deleting.
Helen
Post by Helen »
stubbsonic wrote: Tue Jan 23, 2024 6:15 pm We were just talking about some occasional situation where a MIDI note is assigned to trigger a COMMAND (in the COMMANDS list). In this case, I wonder if somehow the note OFF has been assigned as a command.
Oh, thank you for mentioning your discussion. I would love to see that thread, where is it? DP has been driving me nuts with random changes to the COMMANDS. I use Metasystem, and stuff just stops working, frequently. Gah.
-Helen
Mac Pro Rack 7,1 3.2 Ghz 16-core, OS 12.7.4, 192GB ram
MOTU 828es, DP 11.31, Altiverb, Kontakt 7, VEPro
This job is fun, this job is fun, this job is fun....
Helen wrote: Sat Jan 27, 2024 5:25 pm Oh, thank you for mentioning your discussion. I would love to see that thread, where is it? DP has been driving me nuts with random changes to the COMMANDS. I use Metasystem, and stuff just stops working, frequently. Gah.
Here are a couple...
viewtopic.php?t=73821
viewtopic.php?t=72824
Helen
Post by Helen »
stubbsonic wrote: Sat Jan 27, 2024 7:22 pm
Thank you!
I must be leaving the COMMANDS window open far too much then. It's been a real bugaboo for me. At least I have a plan for avoiding it in the future: Close the darn window!
Re: MIDI Note Off Not Registering - RESOLVED
Yea, I only open the COMMANDS window when I need to be reminded of some shortcut key-combination. Of course you don't need it to be open in order to use commands.
I don't use MIDI events to trigger commands because I haven't needed to. I used to use it for remote functions stop/rewind/record, etc. But these days I just reach over to the QWERTY keyboard. I suppose I can use a USB extention and move the kbd closer to my MIDI controller keyboard.
