Hi all. Been using DP for many years but mostly MIDI and I have little experience doing much with audio. I usually create full arrangements in MIDI, then record-enable audio tracks to “capture” the sequence to multi-track audio.
If I want to have a single, summed track of the mix IN MONO, is bouncing the way to go?
Thanks.
Freeze v bounce
Freeze v bounce
2014 MacBook Pro 15" Retina (10.15.7, 16GB, 500GB SSD), DP 10.13, Ultralite Mk3 (FW), MidiExpress 128, Roland XV5050, Kurzweil MicroPiano, Kurzweil SP6-7, TC Helicon Quintet, Fender American Stratocaster (2000), Martin DCPA4.
Re: Freeze v bounce
Yes, bouncing is the process for creating a single file from many tracks in a mix.
Freeze is when you want to capture the effects applied to an individual track, usually to save resources.
You can freeze MIDI and audio tracks, is my understanding.
Cheers!
Cheers!
MBP i5/i7, MacOS 10.13/10.15, MOTU DP 11, Traveller, Track 16.
Dual 867Mhz G4 (MDD), APPLE 17" Display, MacOS 10.4.11, 2Gb. RAM, 4 internal drives (2 x 120 gbs./8mb cache audio drives in ATA66 bus, RAID stripe), MOTU 896HD, 4 x UAD-1, WaveArts Wavesurround Pro, DP 5.13, Reason 3.0.5, Recycle 2.1, Novation Remote 25SL, Mackie HR624, MGE ups.
