Re: PSP Audioware 2445EMT and PSP42 Updated
mikehalloran wrote: Sun Jan 14, 2024 11:23 am Has anyone succeeded in using PSP's 608MD AU on Apple Silicon? I keep seeing plugin failed.
I just loaded a project and inserted 608MD on a stereo instrument track and it works fine. Looks like the version is 1.7.2
2022 M1 Max MBP running 12.7.2, DP 11.3
AudioThing Fog Convolver version 2.2 released/on sale
Changelog:
Added: Impulse Response Space Simulator.
Added: New Bank: DIY.
Added: More IRs to Unusual bank.
Added: macOS 14 Sonoma support.
Added: AAX Apple Silicon Support.
Fixed: Path issues when moving projects between macOS and Windows.
Improved: Graphic memory usage.
Price: $69. Fog Convolver is available for $39 until February 4th, 2024.
Applied Acoustics Systems Ultra Analog VA-3 updated
Version 3.26 updated to 3.27.
For whatever reason, AAX version lags behind still at version 3.2.5
AAS also updated their Chromaphone 3 to version 3.1.5
stubbsonic wrote: Wed Jan 17, 2024 5:36 pm
I just visited the PSP site to see that all my plugs from them where quite outdated. Current version of 608 MD is 1.8.0-- hopefully installing it won't cause any problems.
stubbsonic wrote:(James, if you paste the link from your email, you are pasting your serial for the plug-in. AAS gives you a specific link for your download-- you should remove that link).
Yikes. Removed. It didn’t make me log in to the website so I didn’t realize that. Thanks.
stubbsonic wrote: Thu Jan 18, 2024 9:24 pm I just visited the PSP site to see that all my plugs from them where quite outdated. Current version of 608 MD is 1.8.0-- hopefully installing it won't cause any problems.
I get emails from them when one of the plugins I have is updated. A little advertising too, sometimes, but not nearly as much as most suppliers.
bayswater wrote: Fri Jan 19, 2024 8:05 am I get emails from them when one of the plugins I have is updated. A little advertising too, sometimes, but not nearly as much as most suppliers.
That's helpful. Will subscribe to PSP now.
Re: iZotope RX 10 Advanced Known Bug - Revert to 10.4 is the Fix
I wrote to iZotope:
Can’t find the RX default sample rate setting.
RX9 opens @48k. Works great. Audio interface sails along smoothly.
RX10 always opens @ 44.1k. This crashes my DAW audio system. If not running my DAW, it forces my interface to 44.1k when I open it.
Their response:
This is a bug with RX 10.4.1 and 10.4.2.
Please revert back to RX 10.4.0 for now until the RX 10.5.0 patch comes out.
Sorry for the inconvenience with the sample rate mismatch.
MacOS:
https://downloads.izotope.com/product_d ... 10_4_0.dmg
Windows OS:
https://downloads.izotope.com/product_d ... 10_4_0.exe
Installed; 10.4.0 works fine on my system
HC Markus
https://rbohemia.com
HCMarkus wrote: Fri Jan 19, 2024 4:45 pm I wrote to iZotope:
That explains a few things. Since it includes look-ahead modules, I removed RX 10 Advanced from my templates. Downloading RX 10.4.0 Advanced now. Thanks for the link and heads up!
These are not on the Legacy Products page.
https://www.izotope.com/en/products/leg ... ducts.html
OK, I just downloaded the current version, ran the uninstaller, then installed 1.8.0; and I'm having the same issue. It fails to install. I would suggest you roll back to some previous version, but the ability to zoom the window is pretty important.
I'll definitely reach out to PSP about this issue as well.
Stylus RMX updated to 1.10.5c
Been a while since I poked around over at spectrasonics.net, but glad I did. Looks like a Stylus RMX update on January 4:
Stylus RMX Software 1.10.5c
1-4-24
Adds support for VST2 to VST3 replacement
Adds new "Load Output Assignment With Part" user preference to the RMX utility menus
Fixes issue on macOS where the instrument repeatedly asked the user to authorize
Fixes issue in Chorus Echo effect where tempo changes could create clicking artifacts
Fixes issue where the Utility -> Magnify Window menu did not always display a checkmark next to the current scaling setting
Fixes VST2 crash that could occur when plugin was placed within sub-folders that contained a space character
Resolves issue where the plugin could receive corrupted host automation values from Logic Pro when modifying automation assignments in the plugin
Windows only: Fixes GUI performance issues
stubbsonic wrote: Fri Jan 19, 2024 9:21 pm
Just heard back from PSP. They are aware of the issue and working on an update, but suggested that I roll back to the previous version. PSP site doesn't appear to offer a download section for previous versions. I probably have the installer somewhere (I do save them). The version history shows that the version just before 1.8.0 is 1.7.2, so I guess I didn't sleep through any missed versions.
PSP Impressor updated to 1.0.3
You know where to get it... https://pspaudioware.com
PSP Impressor v. 1.0.3
New:
1) Presets.
Bug Fixes:
1) AudioUnit: Resizing problem fixed.
2) Cubase 13: Plugin no longer opens in full-screen window; issue resolved.
3) Minor bugs fixed.
Please Note:
1) macOS 10.13 and Earlier: We are no longer supporting older versions of macOS (10.13 and earlier).
2) Windows Vista and Earlier: Discontinuing support for Windows Vista and earlier versions for better performance and security.
Their response:
MacOS:
Windows OS:
Looks like the 10.5.0 version is no available on iZotope Product Portal!
