DP11 backwards version compatibility?
smashprod
Post by smashprod »
I am going to be exchanging DP projects with someone running DP8; I use DP11. Are the files compatible? If so, what should I watch out for to STAY compatible?
Re: DP11 backwards version compatibility?
There's an option to Save As... where there's a pop-up menu in the save dialog that let's you choose a DP version to save as.
I guess the question will be which new features will get lost when you do this version shift. I think your MIDI and audio should be fine. Not sure about plugs, etc.
smashprod
Post by smashprod »
Worked like a charm, thanks!
