Good evening,
I work with two screens. On the first I have the sequence or the editor window with a channel strip. On the second I have the MIDI Editor. Now when I press on the first screen in the channel strip solo this does not work correctly. When I switch from MIDI editor to mixer in the second monitor it works. Anybody know that?
Greetings and Happy Christmas, Denis
Solo does not work correctly when I work with two screens.
- Belushi
G4 1,6 GHz Dual MDD, OS X 10.3.9 Pro Tools 6.41 Mix +, G5 OS X 10.11.6, DP 10.13, Logic 9.18 & 10 ;Melodyne,EZdrummer,V.Guitarist-2,Raging Guitars,NI Komplete, Roland JV2080,S760,ATARI STE,...
Re: Solo does not work correctly when I work with two screens.
Hi Denis,Belushi wrote: ↑Thu Dec 21, 2023 10:06 am Good evening,
Solo is one of those everything affects everything else functions. I clicked on the wrong box accidently once and it probably took me a half hour going through the pdf manual, looking at every mention of Solo and making sure that it was working the way I wanted when I was done.
https://cdn-data.motu.com/manuals/softw ... +Guide.pdf
No one here is going to know the correct solution without seeing your setup. Searchable PDFs are your friend. You can also access it through the Help menu.
- Belushi
Hello,
I found the problem. Under Preference > MIDI Options > MIDI Solo Setup, you have to disable "Solo front-most MIDI edit window."
I find the solo department in DP... how should I say that... quite complicated. Simple is sometimes more.
Have a nice Christmas season and a healthy year 2024, Denis;
