DP11.3 Sequence Editor MIDI Note Visibility while editing note duration -FIXED DP11.32
When edge editing MIDI notes in the SE, the note border goes the same shade of gray as the black note background in my preferred Theme of MoTools, essentially rendering the note invisible while edge editing sharps and flats. Note becomes visible once edit tool is released.
Doesn't do this in 11.23, because the note border is white while editing.
Anybody else seeing this in DP11.3? Thanks!
https://rbohemia.com
Re: DP11.3 Sequence Editor MIDI Note Visibility while editing note duration
HCMarkus wrote:When edge editing MIDI notes in the SE, the note border goes the same shade of gray as the black note background in my preferred Theme of MoTools, essentially rendering the note invisible while edge editing sharps and flats. Note becomes visible once edit tool is released.
Just for clarity and if I get get a contact at MOTU to look at this, could you attach a screenshot maybe? Image
DP11.23.mov
(704.81 KiB) Downloaded 721 times
DP11.3.mov
(586.68 KiB) Downloaded 760 times
If my upload worked, you can see the difference between DP11.23 and 11.3 in these two movies. I tried a new file, one created in DP11.3, and got the dramatic results shown... the disappearing/reappearing note!
ng62gn
Post by ng62gn »
Same issue here.
labman
Post by labman »
Thank you for posting. That is fairly serious I would say. Does it happen on other themes too?
labman wrote: Sat Dec 16, 2023 5:20 am Thank you for posting. That is fairly serious I would say. Does it happen on other themes too?
Didn't try other themes. "I know what I like and I like what I know," sang Peter Gabriel, and I often concur.
leigh
Post by leigh »
With markers a single character marker doesn't stand out from the background. I have to put a space before the character to make it visible.
**Leigh
I tried it with a couple themes, including the default theme, and the outline was either black or white. I wonder if some themes "confuse" its process of picking black or white?
Saxplayerz
Post by Saxplayerz »
It’s working if I use the default theme. Guess we lost themes now.
Saxplayerz wrote:Guess we lost themes now.
You sound like a “glass is half empty” guy. Image I’m sure MOTU will fix it.
Saxplayerz
James Steele wrote: Sun Dec 17, 2023 6:39 am
So break one fix one mentality is a great business model?
Yeah man, I’m sure they meant to do it on purpose. They will get it fixed. You made it sound like themes are gone and lost for good.
Saxplayerz
I’m sure they’ll fix it just as fast as they fixed clippings oh wait they have not fixed that or groove quantize oh wait not yet either
Saxplayerz wrote:I’m sure they’ll fix it just as fast as they fixed clippings oh wait they have not fixed that or groove quantize oh wait not yet either
Well you’re just a font of positivity today! Image
Saxplayerz wrote: Sun Dec 17, 2023 5:18 am It’s working if I use the default theme. Guess we lost themes now.
Use 11.23 if you want.
If the update happened the way mine and others did, 11.23 is still residing in your Applications Folder.
