Hi all,
I'm getting close to the end of another production music album (phew) and have to provide 30 second cut-downs.
I've done this before and it's always messy, so I kinda dread it.
Are there any specific techniques, workflows, tools in DP that might help me out? I'd appreciate the help to make the process less like pulling a tooth!
Darren
30 second cut downs
- dazzjazz
30 second cut downs
iMac 27" 2013 24 GB RAM
OSX Catalina. Focusrite Clarett 8Pre. Heritage Audio HA73.
DP10.
Yamaha CP4. 1961 Hammond A100. Too many Leslies.
Darren Heinrich
BMus (Hons) Jazz Piano
PhD Jazz Organ Improvisation
http://www.dazzjazz.com/
DP10.
Darren Heinrich
Re: 30 second cut downs
My only tip: try both MIDI and Audio tracks when doing cutdowns. Audio gives you predictable control. MIDI gives you happy surprises and flowing transitions.
- dazzjazz
For those who might have the same question, this was my solution:
Bounce out a stereo file of the complete song/piece/track and check 'add to Soundbites'
Copy the markers from the Conductor track.
Within the same project, create a new sequence/chunk
Set the tempo to match
Past the markers into the Conductor track the new sequence
creat a new marker at the 30 second mark
Drag the Stereo file onto the sequence window and make sure it is left aligned.
Set the grid to whole note
Use the scissor tool to cut the track into whole measure slices.
Create a new audio track
Copy the bars you need to this new track to fill 30 seconds.
Crossfade and edge edit where necessary.
This worked well for me - although I'm sure there's more than a few highly experienced people here who are probably facepalming right now.
Hope this helps someone...
DP10.
Darren Heinrich
DP10.
Darren Heinrich
Hey guys I have done those before. How do you deal with the reverb tail at the end ? Part of your 30 or 60 sec piece of music ? Thanks !
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
