Quantize Blacked out running Rosetta
Anyone else having this problem?
Running Ventura on an M1 MacStudio
In order for Audioease Altiverb windows to display correctly I need to run Rosetta
Running Rosetta is making the DP Quantize window blacked out so as I can't control anything.
All apps and plugins are up to date
Advice welcome
Advice welcome
Beth Schafer
www.bethschafer.com
www.bethschafer.com
Re: Quantize Blacked out running Rosetta
Altiverb runs perfectly under DP Native; you don't need to run DP Rosetta.macbethas wrote: ↑Sat Jul 08, 2023 9:09 am Anyone else having this problem?
Advice welcome
Unless something has changed (I doubt it), in order to INSTALL Altiverb, DP must be run in Rosetta Mode.
Here are the instructions Audio Ease provided me when the Mac Studio was first released:
Please try this:
- restart the mac (oh yes)
- then go to the applications folder, locate your DP app, hit get info in the finder and tick the box for the option 'open using Rosetta'
- now run DP, try to use Altiverb, if it works, quit DP
- then go to the applications folder again, and now turn off (deselect) the option for DP to 'open using Rosetta'.
- run DP again, Altiverb should still work.
Best regards,
Aram Verwoest
Audio Ease support
support@audioease.com
Thanks for the reply. Following those exact instructions, when back in native mode I see no measurements in the Altiverb window (screen shot attached).
On Altiverb website is the following:
Apple silicon native support
We are currently working on adding native silicon support to this plug-in. As soon as we have more news on this you will hear from us.
The performance using Rosetta 2 is great. This means you can use this plug-in on an Apple silicon machine right now.
- Screenshot 2023-07-08 at 1.07.05 PM.png (1.04 MiB) Viewed 692 times
Beth Schafer
www.bethschafer.com
www.bethschafer.com
You’re having the font issue that I had once. Not sure how I resolved that, but I will check. I posted a thread here about it.
Here's the thread where I ran into this issue:
https://www.motunation.com/forum/viewtopic.php?t=72967
Here's a link that Audio Ease tech support sent me to supposedly fix the problem:
I never tried it as somehow when I updated from Monterey to Ventura, the issue went away on it's own.
I love this forum.
