Slow
Saxplayerz
Slow
Post by Saxplayerz »
Dp is slow to respond. If I hit play it’s not instant play it pauses for a few seconds. What could that be?
Re: Slow
Do you see if your count in or preroll is turned on?
Phil O
Re: Slow
Post by Phil O »
+1
Also check your prime milliseconds. Info on this in the Getting Started Guide (not the User Guide).
Slow
If you do find a solution, please come back to this topic and share with us. What makes this site valuable, is the repository of information that people can find when they search here.
jim2b
Re: Slow
Post by jim2b »
I’ve had that happen with lookahead plugins. IZotope Nectar has caused that behavior.
I hope that this helps.
Jim
DP 11, High Sierra, Mid 2010 Mac Pro 3.33ghz, 32gb Ram
zounds
Re: Slow
Post by zounds »
Yes, same problem here. It's so bad (2-3 second with just a couple of instruments on an M1 Max 64G Mac Book Pro) that I've taken to always running in Live Performance mode, which of course really increases the processor hit (see post "DP Memory Issue in the "Usage, Techniques, Tips & Optimization board).
Re: Slow
zounds wrote: Sat Jun 24, 2023 1:42 pm Yes, same problem here. It's so bad (2-3 second with just a couple of instruments on an M1 Max 64G Mac Book Pro) that I've taken to always running in Live Performance mode, which of course really increases the processor hit (see post "DP Memory Issue in the "Usage, Techniques, Tips & Optimization board).
Are those instruments in one instance of whatever VI player you are using? If so, they are using only one Core. If you run each VI in a separate instance of your player, the OS spreads the load among the cores. Also true with windows.
zounds
Re: Slow
Post by zounds »
Yes, using the new Enhanced Instrument Tracks with just one track per instrument.
Re: Slow
zounds wrote: Sat Jun 24, 2023 8:36 pm Yes, using the new Enhanced Instrument Tracks with just one track per instrument.
Here, I've had no issue like you guys are experiencing, even while using look-ahead plugins.
I'm sure you have re-booted your Mac... yes?
Have you tried reinstalling DP?
HC Markus
https://rbohemia.com
Saxplayerz
Re: Slow
HCMarkus wrote: Sun Jun 25, 2023 7:59 am
Yes I’ve rebooted the Mac. It’s not the Mac as it works fine in my other daws. No I’m not reinstalling
Re: Slow
Reinstalling DP takes very little time and should not affect your prefs, etc. Don’t know that it will work, but it’s pretty painless to do.
