Antares Harmony Engine Evo
elarue
Post by elarue »
Does anyone have experience using Antares Harmony Engine with DP? I just purchased it and am trying to load it in, but every time I scan it, it says "Failed." How do I work around this issue?
2019 MacBook Pro, MacOS Monterey 12.6.3, 16GB RAM, 1TB HD, DP 11.11
Re: Antares Harmony Engine Evo
elarue wrote: Sat Jun 03, 2023 10:47 pm Does anyone have experience using Antares Harmony Engine with DP? I just purchased it and am trying to load it in, but every time I scan it, it says "Failed." How do I work around this issue?
Not enough information. What version of DP? What MacOS? Have you installed the latest CodeMeter Run Time?
elarue
Post by elarue »
mikehalloran wrote: Sun Jun 04, 2023 7:44 am
DP 11 on MacOS Monterey. I don't know about CodeMeter - where is it and how do I install it?
elarue wrote: Sun Jun 04, 2023 12:17 pm
Antares uses CodeMeter from Wibu for licensing. You must install a CodeMeter run time to activate your license. The instructions on Antares site are a bit confusing but they do work.
Antares does not always have the latest version on their site — this has caused me major grief in the past. Once you are properly licensed, you can download and install the latest version here:
https://www.wibu.com/us/support/user/do ... tware.html
elarue
Post by elarue »
mikehalloran wrote: Tue Jun 06, 2023 10:51 am
Okay, I found Codemeter through a Google search, but I wasn't sure how it worked, so I didn't install right away. Once I saw what it was, I thought maybe it was something that DP used. I had activated my license through Auto-Tune Central thinking that was sufficient, but maybe it wasn't. I'll install the latest Codemeter and see if that does the trick.
elarue
Post by elarue »
elarue wrote: Tue Jun 06, 2023 11:14 am
Okay, installing the latest Codemeter did not do the trick. Not sure if I need to do a clean install of Harmony Engine now or if there's still another lingering issue.
Other than referring you to Antares, I don't know. It does work for my in DP 11 over Ventura. They used to use iLok but I think they switched back in 2017 otr so.
https://www.antarestech.com/getting-started
Shot in the dark, but try launching DP in Rosetta and then rescan the plugin. Sometimes that works.
elarue
Post by elarue »
James Steele wrote: Tue Jun 06, 2023 3:38 pm
Okay, dumb question. What do you mean by "launch DP in Rosetta?" :lol:
elarue
Post by elarue »
mikehalloran wrote: Tue Jun 06, 2023 3:34 pm Other than referring you to Antares, I don't know. It does work for my in DP 11 over Ventura. They used to use iLok but I think they switched back in 2017 otr so.
Yeah, I submitted a ticket with them, and all they recommended was to do a clean install. I told them that didn't work, and then, crickets.
elarue wrote: Tue Jun 06, 2023 5:35 pm
Every owner of an Apple Silicon Mac needs to know this one.
Run Get Info on DP. You’ll see a box that, when checked, opens the app over Rosetta 2.
elarue
Post by elarue »
mikehalloran wrote: Thu Jun 08, 2023 8:15 am
Ah, that's why I don't know anything about this. My MBP is from 2019 and still has an Intel chip. I did look for the box you mentioned and didn't see it there, but if it requires Apple Silicon, that might be why.
Oops. My mistake. Sorry.
elarue wrote: Thu Jun 08, 2023 11:21 am Ah, that's why I don't know anything about this. My MBP is from 2019 and still has an Intel chip. I did look for the box you mentioned and didn't see it there, but if it requires Apple Silicon, that might be why.
Set up a signature with rig details. Helps when troubleshooting is needed.
https://rbohemia.com
elarue
Post by elarue »
HCMarkus wrote: Thu Jun 08, 2023 7:16 pm
Thanks for the tip! Now let's see if my fancy new signature shows up! :D
