Record Beats: up to a half hour to render! User error? Something else? Any ideas?
Hi. Relatively new to DP. I've been trying to use Record Beats reliably. Something must be wrong and I'm missing a key setting or something. It's just two tracks of audio I'm recording to - a bass and a vocal. 3 minutes. Simple enough I would have thought.
Unusual tempo fluctuations I expect; I know there can be spikes and inconsistencies. Which is the point of Adjust Beats afterward right? To refine those rough parts.
But DP is taking forever, absolutely forever to render the resulting tempo map. Around 20-30 minutes. And it's not a brand new machine but it's not ancient (2017 4.2 GHz Quad-Core Intel Core i7 iMac with 64 GB RAM). I've removed all plugins anywhere. Still over 20 minutes to render the map.
Any ideas? Thanks in advance!
Re: Record Beats: up to a half hour to render! User error? Something else? Any ideas?
One thing we discovered many moons ago, is that each time that happens, we will hit cmd period. (which usually cancels the task). IN this case, it finishes it. With no seeming ill affects.
Thanks for the response labman. Appreciate it.
Unfortunately (for me at least) it does cancel the task and doesn't finish the tempo map.
I'm running DP 11.22 by the way if that should make any difference.
Ok, that ain't right but I don't have enough info to know where to begin.cjb wrote: ↑Fri Jun 02, 2023 10:59 pm Hi. Relatively new to DP. I've been trying to use Record Beats reliably. Something must be wrong and I'm missing a key setting or something. It's just two tracks of audio I'm recording to - a bass and a vocal. 3 minutes. Simple enough I would have thought.
You certainly have enough RAM. Rendering is a write to disk task so let's look at that:
2017 iMac — should be a mid 2017 27" if 4.2GHz — correct? What MacOS?
Are you writing to internal or external storage? If internal, Hybrid drive or SSD, how big and and how full (very important)? If external, what are the details including the above and how you are connected?
Another thought.
If something is interfering, it may show up in the Background Processing Window. Go to pg 942 in the DP 11 manual to see how to get it to open and close automatically. If something is interfering, you might not see what but you should see the process that is hanging. Take a screen shot if you can and let us see — also useful if you have to send to support.
If the window does not open, that should indicate the problem is somewhere else. I know of other places to look.
Do you have any Corel products on your Mac (other than Toast)?
mikehalloran, thanks so much for responding. I'm sorry I don't have notifications or similar enabled and hadn't realized you had offered support. Much appreciated!
I actually found a doable workaround. It's a very large template I'm working with and I found that to copy the sequence and delete all the unneeded tracks sped up the Record Beats/tempo map rendering to near instantaneous. With the solution in place on I went.
Still, thanks again for your response and thoughts. I appreciate it!
