11.22 version insstallation failing
- darrell
hi. trying to install DP11.22, but get installation failed screen when attempting. any ideas?
have an intel imac running ventura
Re: 11.22 version insstallation failing
Mine installed fine, though it's not an Intel Mac. Maybe try downloading the installer again?
Was smooth and fast here.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
Went okay here too. I’m on an Apple Silicon Mac though.
OK on two Intels here.
Did you try a) installing from within DP or b) downloading the installer from MOTU?
If a, sometimes an app won't close correctly causing failure. Try b.
If b, might be a corrupt download — it happens. I would trash that installer and try again.
Reboot before running in case you didn't have enough free RAM.
- darrell
Thanks for all the replies! I'm not sure what I did, using my general shotgun approach, but did download the newer version of Ventura, and installation was completed.
Darrell A.
Darrell A.
