Changing Fade Type on Existing Fade?
Maybe I’ve forgotten how this works. Am a bit rusty, but… notice in the attached video I have a pre-existing equal gain fade at the end of the soundbite. I select the fade and click to bring up the dialog and change the fade to equal power. I thought that this used to immediately change the pre-existing fade to the different type, but it I have to “drag” the fade away, then “drag” it back to get it to change.
Again… maybe this is how it’s always been and I’m remembering it incorrectly?
ng62gn
Re: Changing Fade Type on Existing Fade?
Post by ng62gn »
It shouldn't be like that. It should change when you click OK. Here it's working fine. (11.21 / 12.6.3)
ng62gn wrote: Sun Mar 05, 2023 6:54 am It shouldn't be like that. It should change when you click OK. Here it's working fine. (11.21 / 12.6.3)
Hmmmm... Maybe it's a Ventura issue. I'll report it to MOTU.
Works as it should here. DP 11.21 and Monterey. I also saved a with a fade, quit, relaunched, reloaded and tried again, works properly.
stubbsonic wrote: Mon Mar 06, 2023 7:19 am Works as it should here. DP 11.21 and Monterey. I also saved a with a fade, quit, relaunched, reloaded and tried again, works properly.
Yep. Not here. I think it's a bug that might have crept in with Ventura? That's the only thing that changed on my system. If anyone reading this is using DP 11.21 on Ventura, please try this. :)
