Create loop from multiple tracks?
LUG
Post by LUG »
Let's say I have a full band recording (12 tracks or so).
I'm currently looping a little bit to workout ideas. Basically just using start/stop points with the memory cycle button on, etc. Works great!
However, I wonder... Is there a quick-ish way to create a real stereo mix of this loop? As opposed to copy/pasting that little bit in another track manually over and over again?
Maybe some sort of "fancy" bounce to disk operation? Where one can tell it to loop it x amount of times when bouncing?
Thanks for any advice!
LUG
Re: Create loop from multiple tracks?
Post by LUG »
Also, RE: manually creating a loop....
Is the ability to "throw" a track broken now or something? I'm on DP 10.13.
It's like it wants to do it (I see the hand tool but the track won't move when I throw it)? Is there a zoom-level restriction?
Or perhaps there is some other way to stick soundbites together so there's no gap between them?
FMiguelez
Post by FMiguelez »
LUG wrote: Fri Feb 03, 2023 8:13 pm Let's say I have a full band recording (12 tracks or so).
You could just bounce the length of the loop if there's a corresponding time selection and their signal goes to the main out.
For the track "throw" you want I think you need to press Control while you drag the track.
You could record the loop mix once; then use the Repeat function on the recorded mix track to repeat as many times as you specify, then merge
HC Markus
https://rbohemia.com
