Michael Canavan wrote: ↑Thu Jan 12, 2023 2:26 pm
OK now I'm getting it. You're not using the commands that specifically apply to consolidated instrument tracks.
I don't understand. I got these commands from the manual. See. pp 162-3. How do they not specifically apply?
Merging MIDI tracks into an instrument track
If, at some point, you need to combine one or more separate MIDI tracks into an instrument track, use the Merge by Channel command (in the Commands window in the Setup menu) as follows:
1 Assign the MIDI tracks to the virtual instrument instantiated on the instrument track (if they aren’t already).
If the virtual instrument is multi-timbral and supports multiple parts receiving on separate MIDI channels, assign each MIDI track to the appropriate channel (part).
2 If the instrument track is a “legacy” track (that can’t hold MIDI data), convert it. See “Converting legacy instrument tracks” below).
3 Select the MIDI tracks and the instrument track.
4 Invoke the Merge by Channel command, either by pressing the keystroke you’ve assigned to it in the Commands window, or by using Run Command (shift-spacebar).
The MIDI tracks are now consolidated into the Instrument track. Channelized MIDI data inherits the output channel assignment of its source track, allowing you to easily combine multiple channel streams. (See “Multi-channel MIDI tracks” on page 144.) If you need to change the MIDI channel of any data in the merged track, use the Change MIDI Channel command (Region menu).
Splitting an instrument track into separate MIDI tracks by MIDI channel
If an instrument track has multiple MIDI channel data streams, and you wish to split them out into separate MIDI tracks, use the Split by Channel command (in the Commands window in the Setup menu):
1 Select the entire instrument track, or the portion you wish to split out.
2 Invoke the Split by Channel command, either by pressing the keystroke you’ve assigned to it in the Commands window, or by using Run Command (shift-spacebar).
The resulting separate MIDI tracks remain assigned to the instrument track.
