STL Tones Control Hub 1.1.1 AU crashes DP 11.21 RESOLVED
Just a heads up to any other users of STL Tones' Control Hub, that the new update they pushed out today, version 1.1.1, crashes DP 11.21 immediately upon instantiation. This is with the Audio Unit version. I did not test to see if the VST does this or not... I just reverted to the previous version.
Also, if you attempt to open any DP projects that have this plug in already on tracks, it will crash DP immediately. Reverting to the previous version of Control Hub will fix it. Hopefully you have a backup. Not sure STL makes previous versions available for download, but if you need it, PM me. I don't have the installer anymore, but I can send individual component files.
Additionally, you can launch DP in Rosetta mode if you want to be able to see what tracks you have instances of STL Control Hub on and delete those instances, but really best thing to do is just remove version 1.1.1 and revert to previous version.
Re: STL Tones Control Hub 1.1.1 AU (released 10/28/22) crashes DP 11.21
Well I have to give STL Tones some MAJOR kudos. This all happened TODAY:
1:54pm PST - I sent email about the problem with the crash log to STL Tones.
6:40pm PST - I receiving an email from STL asking if I’m running the most up to date version of iLok License Manager. I immediately reply “Yes.”
7:47pm PST - STL sends me an email with a dropbox link to a new 1.1.1 version installer and asks me to test it too see if issue is persisting. It is NOT! Plug in fixed!!
Impressive, STL!!
