DP 11.21 Released
DP 11.21 Released
It’ll be a while before I get a chance to go through the release notes.
Re: DP 11.21 Released
Thanks for the heads up cuttime!
Enhancements introduced in version 11.21
Enhancements and optimizations
• Changed Beat based Audio to MIDI to ignore disabled beats.
• Changed default key-binding of "Add Multiple Unassigned Instruments" from cmd-shift-opt-I to cmd-shift-opt-U. It was conflicting with "Add Instruments With Options."
• Tweaked the VST3 validator to pass Arturia plug-ins.
Fixes
• Fixed a crash when setting Polar I/Os.
• Fixed a problem where ARA preview effects were not being installed when duplicating tracks.
• Tweaked the code the removes MIDI tracks from v-racks to avoid a crash.
• Fixed a problem in VST2 and VST3 wrappers where tempo would double if the current meter had 8 as the denominator.
• Fixed a crash that could occur when opening a control surface effect selection list on installs containing effects with long names.
• Fixed a problem where you couldn't use the track assigns dialog on combined instrument tracks.
• Fixed a problem where the display of MIDI inputs on tracks wouldn't update when using the track assigns dialog.
• Fix crash when using scrub tool in waveform editor.
Well, that should resolve some issues.
I’m liking the frequency of updates lately. Keep it up MOTU!
mhschmieder
Post by mhschmieder »
That was a quick installation! I'll give it a try later tonight; I had just finished a session when I saw this post.
James Steele wrote: Wed Oct 19, 2022 3:00 pm I’m liking the frequency of updates lately. Keep it up MOTU!
Yes! This may be the quickest update cycle I can ever recall.
dix
Post by dix »
cuttime wrote: Wed Oct 19, 2022 3:39 pm
Indeed! And 11.2 was already super stable out of the box.
My two little pet bugs are still there (crash on drag audio to desktop, and the broken constrain MIDI dragging between tracks in the SE), but the idea that those'll be fixed one day is more of an aspiration than a need at this point.
dix wrote:My two little pet bugs are still there (crash on drag audio to desktop…
That one seems intermittent and hard to nail down. I think I posted this screen capture in another topic of me doing that on my system with no crashing.
dix
Post by dix »
James Steele wrote: Fri Oct 21, 2022 11:26 am
Here’s me:
So the million dollar question: why you and not me?
Drag to desktop was an almost guaranteed crash for me; every once in a while, it worked. But I stopped trying awhile ago.
I have't tested 11.21 yet.
HCMarkus wrote: Fri Oct 21, 2022 1:56 pm Drag to desktop was an almost guaranteed crash for me; every once in a while, it worked. But I stopped trying awhile ago. I have't tested 11.21 yet.
That's so weird. I have to try it again. When I made that video, I did it over and over and OVER trying to get it to crash. dix, have you sent crash log to MOTU?
dix
Post by dix »
Actually, I rarely need to drag audio to the desktop, but if there’s any desktop showing at all DP will crash if I drag audio between windows/editors within the
NOTE SPELLER still broken. I tested it and it failed on the first try. Couldn't get it to work with my usual tricks. So perhaps worse now?
Well... it's so strange. Just opened a project and dragged several different soudbites to the desktop from both the TO and the SE and no crash. The soundbites were AIFF format. Don't know if that would have any bearing on it.
