MCU is corrupted on just one project
Killahurts
Post by Killahurts »
I have a single project that somehow got the track publications corrupted. MCU still works, but the track order doesn't correspond with the faders on the console. The problem existed before I updated to 11.2, and the update did not fix it either. They are out of order bank wise, and also within banks. e.g. the sax track is number three from the top in DP, but on the console it's 100 tracks further down, near the bottom. I tried everything, including starting a fresh new project and loading everything in from the old project. It made no difference. I've reset Control Surface Setup multiple times, etc. If you move one of the corrupted tracks somewhere else, MCU doesn't change its location on the control surface. Weird.
It only happens on one project. All the others I'm working with do not show any signs of this, and MCU is working perfectly. I'm forging ahead with the project, as everything else seems to be working.. but it's going to be pretty inconvenient for me when it's time to mix or do any comping work.
Does anyone know if there's a way to reset the tracks order/location info that is sent to MCU from DP? I would think that turning off and resetting the Control Surface Setup would do this, but apparently not on this project.
primeevolutionary
Re: MCU is corrupted on just one project
Post by primeevolutionary »
Are you only using one controller (MCU only, or, with Expanders)?
Do you want to try sending the project to me to see if it happens on my MCU?
Macmini9,1 (M1, 2020) 16 GB RAM
MacBookPro15,1 2.6 GHz 6-Core (Intel, 2018) 16 GB RAM
OS X 14.7
DP11.32
2 896 mk3 192 kHz Hybrid FW • USB2
Stage-B16
2 828 mk1s
MTPAV USB
