MIDI recording late
dewdman42
Re: MIDI recording late
Post by dewdman42 »
There are several things which I reported to them over the past year and had some back and forths about...that was one of them, but several others...also not fixed.
For example, DP11 currently has a little bug some of you may or may not be aware of...but with VST3 instruments, when you try to send CC messages from DP to the VST3 plugin...there is a glitch with the values 65-127. They are offset by minus 1. so sending 0-64 works as epected, but sending 65, results in 64 being received by the plugin..and all the way up to 126 being the highest value that can be received by a VST3 plugin since it will be 127 minus 1. I have replicated this on several different VST3 plugins inside DP11. To be honest they kind of blew me off when I reported it and sure enough, it was not fixed in 11.2.
smashprod
Post by smashprod »
Has anybody tried today's update (11.2) to see if the MIDI timing bug is fixed? I don't see anything in the change notes.
I'm finishing up a TV score totally in Pro Tools (thankfully very little MIDI recording/editing), and am avoiding DP for serious scoring work until I can switch to M1 Silicon after my November airdate. It's been so great to be able to record MIDI and have it play back exactly how I played it!
dewdman42
Post by dewdman42 »
yes, as I said in the last comment, they didn't fix it and yes I tested it.
smashprod
Post by smashprod »
Sorry I didn’t read carefully. Too bad 😢
