Below is the download link to the ZIP file with the necessary files and instructions as to where they go. UPDATE: These have the audio previews AND INCLUDE FILES MISSING FROM PREVIOUS VERSIONS. I apologize profusely. THESE will work correctly!!
Here is the link to download the archive:
https://motunation.com/files/TruePianos_NKS_Files.zip
Here is the READ ME which is included in the ZIP file.
8/3/22
I put together these NKS support files for 4Front True Pianos Virtual Instrument. It supports the factory presets for the Amber, Atlantis, Diamond, Emerald, Sapphire, and SapphirePed modules. Audio previews ARE INCLUDED in this version. You must have the True Pianos VST version installed for Komplete Kontrol.
The folder names indicate where the files should be copied.
After copying the files over, launch the standalone Komplete Kontrol app. Depending on what you set in the preferences it should rescan the User Library, but to make sure, you can go to Preferences, click "Library" from the left panel, then click the button labeled "User" at the top, and then click the "Rescan" button at the bottom right. Then close the window. If you are using a Komplete Kontrol series keyboard, it may also be a good idea to then quit and relaunch Komplete Kontrol so it clears out the memory of the keyboard.
NOTICE!!!
These files shouldn't cause any problems with your system, and if you get unpredictable results in Komplete Kontrol, you can just go back and remove them and then rescan your User Library. Nonetheless, given the litigious nature of society, I ASSUME NO RESPONSIBILITY for any problems caused by installing these files on your computer and promise no technical support whatsoever. It should be straightforward enough. Thanks.
