Dp10 randomly crashing using cue next chunk
Anyone have a fix for this
Re: Dp10 randomly crashing using cue next chunk
Not a lot of info to go by. Have you tried trashing plists? Have you called or submitted a techlink to MOTU?
Yo Viggie!
When you switch chunks in DP everything in the first chunk has to be disengaged and then everything in the next chunk has to be engaged. If crashing when changing chunks my speculation is that either the from chunk or the to chunk has some sort of problem initializing/deinitializing.
You usually have audio tracks and maybe some MIDI tracks in your sequences, yes? Any VI tracks? Any effect plug-ins on any tracks?
Have you checked the Bundles window? Any duplicate bundles?
Does the crash happen only with specific chunks or could the crash happen between any combination of chunks?
Dave
Dave
What’s up brother it happens randomly and not always the same chunk I’ve done the bundles check and all the other things and the fact that it happens randomly there’s know way to know if I fixed it...
Hello!
any update on this?
I'm running Mojave and upgraded to DP10 at the start of my tour and I'm experiencing the exact same issue.
Motu tech support is recommending to use DP11 of course but I don't like changing anything mid-tour.
Thinking of rolling back to 9 where I didn't have any issue with the exact same project, although I do like some of the new features on 10.
Thoughts?
any update on this?
Thoughts?
