How do you do this- automation changes
mikeharper
Post by mikeharper »
Hello
lets say I have a track that needs to come down a bit - maybe 1 DB or less. But I don't want to change the automation values. Is there a way to select all of the nodes and use hot keys to nudge the values?
DP10
Asus 490a, Win 10 pro,
Intel Core i7-10700K Comet Lake 8-Core 3.8 GHz LGA 1200
Samsung 970 EVO PLUS M.2 2280 Audio & sample drives
16G ram. MOTU 8A USB3-Thunderbolt
Re: How do you do this- automation changes
You can do that in the Sequence Editor. Just click on a Volume Data point, then drag across the desired range then drag the selection up or down as needed.
Easiest: just insert a Trim Plugin (MOTU stock) on the track and set to -1.0 dB.
https://rbohemia.com
mikeharper
Yeah I have been using the sequence editor method but its a little clunky for me
DP10
CharlzS
Post by CharlzS »
Select the track in the SE so that all the soundbites are selected and then 'Set Bite Gain'. There isn't a key combo assigned to that. You can assign one or shift-spacebar and start typing 'set bite'. It will come up and you can set to whatever you want.
fdco
Post by fdco »
mikeharper wrote: Fri Jul 15, 2022 9:54 am Hello
Sure there is.
In the sequence Editor, select all the automation nodes you want to modify then select
Menu Region > Change Continuous Data… ( ⌃⌘ C On my computer )
Click "Audio Volume" and type a value in the "Add XXX to All Values".
Rinse and repeat.
Mac Book Pro M1 32gb -2TB,
Apogee Symphony Thunderbridge,
DP11, MTPAV, Linnstrument, Chapman Stick
mikeharper
ahh I will try
DP10
