This update includes various optimizations, stability fixes, and enhancements, including a new feature for saving/restoring Aux Mix presets within the Aux Mixing window. Go get it at MOTU's download page
Devices associated with this update include:
112D
1248
16A
8M
24Ai/Ao
Monitor 8
Stage B-16
UltraLite AVB
624
8A
8D
LP32
M64
828es
8PRE-ES
MOTU Pro Audio Firmware Update 1.4.0 now available!
Just saw this on Facebook and I'm blasting this in the Hardware and DP Forums:
- joelfriedman
Re: MOTU Pro Audio Firmware Update 1.4.0 now available!
WARNING: The original firmware did NOT work with the MK4. It turned my into a brick. They've replaced the firmware. I spent 20 minutes with Matt from MOTU and we reverted to the previous version and then updated to the new new firmware and we are back! I believe this is UltraLite MK4 only.
Joel
Joel
Joel Friedman
2023 Mac Studio Ultra M2, 4TB/128GB (external 4TYB sample drive), OS 14.5. MOTU UltraLite MK4, Nektar Impact LX88
DP 11.3.2, MachFive 3.2, MX4 2.2, Ethno 2.01, Komplete 14 Ultimate (don't ask...), Sibelius Ultimate, Symphobia v. 1.06, assorted libraries...
MacBook Pro M1 16 GB RAM OS 14.5
- dado
Same here - I'm very disappointed
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
Did you get it fixed? Joel posted elsewhere how he fixed it. He re-downloaded the firmware which is the newer version, and then reinstalled that I guess. There’s more information in another post.dado wrote:Same here - I'm very disappointed
- joelfriedman
James, Dado,
It does fix it. You can call MOTU if you want them to walk it you through it (was put in the cue, received a call from Matt in about an hour). Otherwise the firmware is on their site. You do need to downgrade to the previous version, then find the new one, download it, open Pro Audio Control in your browser, and look for the tab near the bottom that says update/update by file. Find the file and hit OK, etc. I'd restart.
This is only necessary if you're one of the"early adaptors" who downloaded the "bad" file during the 1st day. It's been replaced on the "good" one.
Best,
Joel
Best,
Joel
Joel Friedman
Motu 1248 with windows 11. since firmware update, cannot access pro audio control. I'm receving a wrong version error after 5 minutes. How I'm suppose to work with that!
Look at the post directly above yours. Maybe that will help?
What browser? Since the firmware update I have a problem with Pro Control in Edge, but Firefox works fine. Try Firefox - type localhost:1280 into the address bar to load Pro Control. BTW, you're posting in the Mac forum.
- dado
I don't see where can I download the older firmware for Pro Audio Controller. I see only the firmware for UltraLite mK4 ( and I have the latest )joelfriedman wrote: ↑Fri Apr 15, 2022 9:59 am James, Dado,
Best,
Joel
