buss conection messed up
lexp
Post by lexp »
Hello,
I have a problem with the busses connection in digital performer 9
and would be very happy, if anybody can help me…?
I have two setups running dp9.52 :
one in my studio:digital performer9.52 / imac 27/ i9, firewire metric halo audio interface 2882,
and
one at home:digital performer9.52/ macpook pro 15/ 2,5ghz/i7, motu 828mk2 firewire audio interface.
I have an issue, when trying to open a project, that was created at the other system:
all buss connection made in the project are messed up/ are not correct any more...
-thanks in advance !
Oliver Vesper
Re: buss conection messed up
I think you need to Delete the assignments in the Bundles Window, then Load (File Menu) the Bundle that works properly for the respective system. Should fix it.
I don't think you need to delete the assignments first, but if you do, you won't have lots of bad vestigial assignments.
Haven't had to do that do this for awhile but I think that is the easiest way to get things straightened out. If the procedure works for you, you might want to create a simple project on each computer with the proper Bundles assignments ready to Load when you need them.
HC Markus
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 14.73 • DP 11.34
https://rbohemia.com
I've had buss connections get broken, possibly due to DP mis-interpreting some state of connected hardware. The only way I could fix it (IIRC) is to start a new project and import the chunks using the "Load... " option from the file menu.
Try HCMarkus's suggestion first, though.
Yes, Loading the project into an existing project on the new computer (omitting Bundles when loading) is pretty much the same thing.
lexp
Post by lexp »
thanks a lot for help !!
yes, loading a chunk was the only way that seems to work-thanks !!!
I thought (hoped) that there is maybe another way to solve this problem
-maybe by "syncronizing" some deeper preferences or anything inside the programm content ...or
library ...or...
to make the program bundle/bus system the same on both setups,
so that I can just work on the same projekt at two different places....
Thanks !!
(sorry for my english by the way...)
