Hi all, I have been doing a once in a 20 year archive and out of 80 DVD backups 2 wouldn't load, I went over to a friends place and used his DVD drive but the icons for DP have changed to the unix exec ones, is there a way in terminal to change them back to DP.
I'm on DP7, also the audio files are not corrupted and play fine in QT
Much thanks brains trust
Boot your Mac in Safe mode with the Shift key held down. Log in when prompted and wait till your desktop icons finish building. This used to be called Rebuilding the desktop and was done the same way before OS X.
If this does not work, you will have to change them manually.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
kassonica wrote: ↑Thu Apr 07, 2022 10:57 pm
thanks mike but they are now on an external drive... do you know how I can manually do it?
This function is as old as the Mac:
Run Get Info on the file. Click on the icon in the window. You can Copy and Paste icon images here.
So, if you have a good icon image on any file, Copy it in Get Info. Now run Get Info on all the files with the wrong icon, click on the image and Paste.
